May 22, 2024, 11:44:16 PM
Volume low on Alesis Wildfire 60 after replacing input jack
Started by murphzerg, March 01, 2012, 07:05:55 PM
murphzerg
Hi All,
This is the first time I am posting on this board, I am hoping you all can help me out. I had to replace the input jack on an Alesis Wildfire 60 and now the volume is about 20% of what it was originally. I have verified the connections. Any suggestions?
Thanks in advance!
Murphzerg
Quote from: murphzerg on March 01, 2012, 07:05:55 PM
Hi All,
Thanks in advance!
Murphzerg
Check over your soldering.  It sounds like you could either have a bad connection or a shorted connection (glob of solder touching two or more things instead of just the one connection it should have).
Good advice ^^^^^
Question:  did you install the exact same type jack or did you rewire for some other jack?
