May 25, 2024, 09:58:50 AM
Guitar amp 12V 40+W...
Started by KeithBraithwaite, October 11, 2011, 04:45:27 PM
KeithBraithwaite
I'm new here so I hope I'm not asking a question that has been turned over many times already.
I need to build a portable solid state 12V amp 40+W feeding a 10" speaker that I've built into a separate portable round box. I've already stripped down an AmpCan (20W) and used the separate parts as a portable unit - I've also done the same with a Peavey 12V unit. I need to up the volume and limit feedback...
I wondered if using a readymade 12v car radio amp with a preamp would do the trick?
I'd be very grateful for any ideas
Keith
20W PER CHIP IS ÈASY, THAT'S WHAT Amp can, peavey solo and many others ùse.
a trivial solution would be using 4 chips, each driving its own speaker
looks kludgy but you forget about switching converters, so ............
or .... buy a  cheap car amp, which already includes them
just be aware that 4500W PMPO usually means about 15 w rms :lmao:
KeithBraithwaite
is that 4500W or 450W ?
I presume I have to use a preamp to drive a car radio amp? What would you suggest?
KeithBraithwaite
I've read all that interesting discussion in the Watts -v- Volume posts and I plan to put in the best quality 10" speaker I can afford. Hopefully this will improve not only the sound but the perceived volume.
450 and 4500 mean about the same in the PMPO world, that's to say, nothing.
That's why my quote was followed by a  :lmao: sign.
If you want to use a single speaker you'll need a car radio amp with a built in converter.
Preamp? We don't know what you want to amplify.
KeithBraithwaite
"450 and 4500 mean about the same in the PMPO world, that's to say, nothing."
Oh dear - seems I'm in a different world. How can 450 W and 4500W = 15 W RMS if they mean nothing. I'm sorry I just can't follow that. Figures have to mean something to me.
I want to use this setup for an electric guitar but I'll also need a similar setup for a synthesizer and an electronic drum set.
Unfortunately, although I'm quite capable of building a kit (despite my 71 years...) I'm very hazy about matching Ohms, knowing what preamp to use (or even whether to use one...)
I really need a list of things to get:
What preamp - if necessary (12v)
What amp or amp kit (12v - 30/40/50 watts RMS)
What speaker (10")
I'm thinking you will have a hard time getting a car amplifier in the 30-50w range.  I do remember a 2 x 40w car amp a while ago though and that could work driving two speakers, or just use half of it.
You will need a preamp between the guitar and the car amplifier.
As for the 450-4500 PMPO watts being 15wRMS or also being nothing that is because "PMPO" stands for "Peak Music Power Output" and isn't a "real" rating.  You will want to make sure you are looking at PEAK and RMS wattage ratings.
All that said, I would honestly try a 20w amp with a high efficiency 10-12" speaker and see if it does it for you.  20w is a fair amount of power unless you are competing with drums and/or another (loud) guitarist.
KeithBraithwaite
Well... I'm "competing" with a whole marching band... Obviously I'm not hoping to outplay 8 trumpets or 16 clarinets (not to say 76 trombones...) and if this works I'll be building at least four units which will even things out a bit. This is not the only use of the setup I'm building though the prototypes are already being used in this context.
I'm thinking of buying a Celestion Greenback 30 watt CEL-G10 GREENBACK 30-8 OHM to hook on to my Peavey 12v (20 watt) amp
I'm hoping there'll be advice from the forum about the models to try - bearing in mind that my budget is fairly tight and that weight is a factor.
I believe that Neodymium magnet speakers are lighter than most others. Are there any reasons for not using them?
Now we have a better idea about what you need.
84 brass!!! Plus assorted extra instruments .... plus drums, cymbals and what not.
That's LOUD !!!!
Starting with speakers, Jensen Mod are efficient (they are specific for Musical Instruments) , for a very attractive price tag.
Buy a couple Mod 1035 or 1050 in 4 ohms and drive them with your AmpCan or Peavey Solo, specially because they provide the preamp you need ready built.
You'll like them.
If you want more power, add more 10" similar speakers, each driven by a 20W amp.
I think Velleman kits has a couple offerings in 12V "car amp" version.
I'm trying to keep this as straightforward as possible for you, avoiding etching and drilling boards, using what you have (which is good stuff).
Will you march on foot with your amp strapped to your neck and the 12V battery in a backpack or you have "something on wheels" available?
KeithBraithwaite
Thanks for getting back to me - I was joking about the 76 trombones - I was quoting from the song in the musical and the film, the Music Man (1962) - I'm old enough to remember it though there was a TV remake in 2003.
I only have 8 trumpets, four bugles, two trombones and 8 saxes against me + all the percussion: 6 snares and two bass drums...
My first prototype was an acoustic guitar I cut part of the back off, put the speaker behind the sound hole and the amp and battery inside. Very neat but feedback at about half volume.
I now have the speaker in a separate box attached to the guitar (imitation Stratocaster) but using insulating rubber pads. The battery and the amp are in a smallish squarish bag with shoulder strap - just like what marching band players keep their music scores in.
I want to keep it as neat as that - just going up to 10" for the speaker - or as you suggest, putting in two. That could be neat too: one below the guitar and one above or at the end. I'm going to get me an odd shaped guitar like a flying V, a Dean V or something like that so as to fit in a couple of speakers more easily.
Try to separate them from the guitar body and save yourself some trouble.
I'd build the whole amp in a back pack, with the Amp Can driving a 10" 4 ohm speaker firing to the right, an extra car 20W chip (or the Peavey solo guts) driving a 10" speaker firing to the left, and the SLA/GelCell 12V 7A battery which powers both, in the bottom of the backpack for stability.
The whole thing is ergonomic and can be worn comfortably for hours while marching.
KeithBraithwaite
Thanks for this overall view of a workable setup. I do already have the amp and the batteries in my shoulder strap bag - backpacking is a bit frowned on over here (France) in marching bands though some in Holland actually have a mock back pack - civil war style. The first time I tried out this idea I used my Ovation with everything else - including the speaker - in a back pack, way back in 2002...
I may try out a system with a speaker on each side though it will need to be more or less fixed using maybe a rigid harness like the bass drummers or some of the more modern multi-tom percussion players. I have been able to cut out all feedback by fixing an aluminium plate to the back of the guitar and fixing the speaker box to this plate at about one inch from the guitar body. The fixing is a large glued rubber pad 5mm (about 1/4 inch) thick. I'm still rather attached to the idea of my "autonomous electric guitar" as a single instrument even if I insist on the idea that it can easily be reduced to a "normal" electric guitar...
I've ordered the Jensen speaker so I'll soon be in a position to judge what my existing amps push out with a good speaker.
I'll keep you posted
Keith
Quote from: KeithBraithwaite on October 16, 2011, 12:59:49 PMI've ordered the Jensen speaker so I'll soon be in a position to judge what my existing amps push out with a good speaker.
Keith
Excellent, I know I am very interested in how this project comes along.
