May 25, 2024, 04:03:03 PM
Amp turns on, then volume falls and sound gets distorted
Started by Simarde, January 03, 2011, 05:19:45 PM
Simarde
Hi guys,
I've been given an old Traynor TS-50 amp, which semi-works. Here's the problem: Let's say I plug my guitar in the amp, while is it turned off. I then strum a chord, and turn the amp on. I can hear the chord for a fraction of a second at normal volume, then the volume falls and the sound gets distorted.
What can it be? A lot I guess, but if it works for a few second, the problem can't be that complex? ???
Quote from: Simarde on January 03, 2011, 05:19:45 PM
Hi guys,
The problem could be quite complex, or it could be quite simple.  How much electronics experience do you have?
I'm thinking it is a problem with the power supply.  Sounds to me like faulty (read: exploded, ruptured, leaking) capacitors on the PSU.
My first thought is that somewhere in your preamp you have a serious DC offset, and you hear the sound come through as the system comes up to voltage and stabilizes.
Simarde
Oh I see. Is there a way I can test the capacitators? And/or repair these? If they're broken I guesse I have to change 'em
Start by googling its schematic and posting it here, so we all speak about the same.
I for one did not mention capacitors, I am more expecting an op amp skewed over to one rail.
Quote from: Enzo on January 04, 2011, 02:39:38 AM
I did mention caps, specifically power supply caps.  And I still think that may be the issue.
If you open up the amp and look for the big soda can looking capacitors, if they have failed they are normally blackened, bulged or split open.
You are right, you did, I am sorry.  I lost my focus there.  Winter blues...
