May 23, 2024, 02:10:51 AM
Peavey Heritage VTX ..uh oh..
Started by ohmy!!, July 08, 2010, 04:28:32 PM
bry melvin
check the tube pin contacts: they often spread and don't make good contact. Some blue is often normal with mordern tubes (often test gassy too...not as deep a vaccumm) however loose tubes can cause lots of problems. As you saw a change when tapping the tubes  would take a good look at contacts AND clean any carbon trails off of the sockets especially since you started with a redplating problem on this amp.
ohmy!!
The tubes were a little loose.  I also took the board out to check the soldering.  One of the driver transistors needed to be soldered better, it also had a huge dead bug stuck to the pins  :o.   Transistor  Q6 was also a bit loose.  So far it's playing normal now, actually sounds a little different than before.  Hopefully it will stay that way.  I'll clean off the contacts on the tube sockets for good measure.
The poor little 6 leg bug wanted to make love  <3) to the huge 8 leg tube and got zapped.
Love is blind :( .
ohmy!!
 ;D It would seem so.  Anyhow I think it's all good now, I played it for hours on end today and cranked it up really loud to test it (about half-way on both channels combined with a distortion pedal).
