Solid State Sleuths (Episode One)
Started by saturated, Today at 07:29:42 PM
saturated
The case of "it looks like a transistor but might be a voltage regulator"  :grr
Some preliminary test results
Spoiler alert: I have no idea what it is
At this point I think some resistance testing might tell us something
And I wish I remembered reading something about the base collector junction being reverse biased  xP
Maybe I can assume just arbitrarily designate one terminal as the base and go from there
Here in 1994
Things are different than before
saturated
Resistance results
At this point I'm inclined to call terminal one the base
Terminal two the emitter
Terminal three the collector
Time to go look at some books 📚
Here in 1994
saturated
Oh well figured I'd try it out
Made up a circuit gonna see if I can apply voltage until there is some emitter current
Was gonna have two power supplies but for now V1 = V2
 xP
Here in 1994
saturated
Change in plan
I put an LED between ground and emitter resistor
Looks like it works
Now...idk why a clear white LED turns red when illuminated  xP
Ok to get a barely detected illuminated LED I have to have 1.7 V at the base and I get 4.2 mv across R3
Yeah I know it's a crap randomly assembled circuit
Here in 1994
saturated
I think I might be out of luck yet .
No matter what I do the collector current is about twice the emitter current (voltage drops that is the resistors are the same value)
At first i suspected the LED but the components are in series so the current and voltage drop should be the same
Might be time to ground the "emitter and see if it behaves like a voltage regulator  :grr
Here in 1994
saturated
#5
Alright guys the results are in but I'll wait  :tu:
Btw I'll be glad to do anymore testing requested
Here in 1994
