Single shot tube tester ?
Started by saturated, November 11, 2026, 08:12:36 PM
saturated
Seems like a person could take one of these
And build the appropriate circuit needed to test
I reckon simplest example would be a diode rectifier tube.
Just add one of these old power supplies that has the 400 (?) V DC and  6.3 for the heater
Downside would be extremely limited application per configuration
Upside would be the lack of a million knobs and switches and stuff some of these testers look like an enigma machine from Blechley Park
Another downside would be getting killed by 400 V DC
It would be cool though seems one could learn quite a bit from it if he/she survived  xP
But then me thinks that someone could spend time and money doing it then one of you guys could tell more in 60 seconds with a multimeter  xP
Reality on vacation
All across a blinded nation
Mentally under sedation
What's wrong with single trick ponies?
As long as it's a trick you NEED and can't get done otherwise.
I made a quick GO-NO GO tester for power tubes.
I apply 60V to plate, 300-350V to screen, 0V to grid, 6.3V to filaments and measure plate current.
It is the peak current it will pass in a saturated Guitar amp.
Per datasheet a power pentode (6L6, EL34) *must* give me around 200 mA.
_Just look at the data sheet_
IF so, tube is perfect.
IF down to 100 mA: it will "work", sort of, but is quite worn, amp will put out less than half power.
Which _may_ still be usable.
I have measured many "still working" Twins and Plexis with original old tubes putting out 40-60 clean Watts.
Which is pretty loud anyway but far from spec.
Anything less, it goes into the dustbin.
Tassieviking
saturated
Yes sir thanks nice to hear from you all btw
HAPPY HOLIDAYS  :tu:
I looked at those links WOW  :dbtu: those are some beautiful works of craftsmanship  :tu:
Some impressive skills by the creators of those so nice  <3)
With that said now back to my junk pile
I don't yet have a 400V DC and 6.3v power supply so I figured well hell maybe I can scare up an old rectifier tube and play with it
So I dug out this old (grid dip oscillator?)
Unfortunately I do not see a rectifier tube and I do see some type of plug in for maybe a solid state rectifier idk
Oh well time to look up and see what a 6AG7 and a 6L6 are and what the heck they do
Also idk how to get these old rusty tube covers off I tried to gently twist and pull up to no avail maybe the whole shebang unplugs maybe the covers arent supposed to come off.
Reality on vacation
Older tubes were metal.  Those covers do not come off.
saturated
Yes sir thanks
Wow I was wondering what type of solid state bridge rectifier was missing from that four pin socket  xP
And then now I was looking for some cheep rectifier tubes to play with learning about the difference between 5ar4 and 5u4gb next thing I know I see a tube for sale
RCA Type 80 Rectifier Tube
With four pins  :tu:
Reality on vacation
Quote from: saturated on November 28, 2026, 07:23:40 PMYes sir thanks
With four pins  :tu:
Actually no more than 4 pins are needed. 2 anodes, 2 filaments which is also the cathode.
