The 358's shall rule the night
Started by saturated, October 12, 2026, 08:35:29 PM
An LM358 is a regular Op Amp and works as such. Only it is cheap, cheap cheap and to boot cheap. Did I say it´s cheap?
11 cents by the unit, certainly less by the 10s of thousands.
NOT DESIGNED FOR AUDIO, original Op Amps (741, etc.) weren´t either.
It is a very useful one widely produced INDUSTRIAL Op Amp for zillions of applications, perfect for non Audio applications such as temperature and water level sensors in washing machines, inside cars, etc.
It was optimized for that duty, so for example is perfectly happy with a SINGLE +5V supply, output can reach ground, etc.
Try that with most any other Op Amp and it fails.
They made it low current consumption by the crude method of biasing output Class B (no idle current) , bad for Audio (crossover distortion) , no big deal when you are controlling a coffee pot or a waffle maker.
They are so useful that I always keep a 50 unit stick near my bench.
11 cents each!!!!!!
Now let me tell you a secret.
My bell ringed one Saturday night, say 10 PM.
I used to live in a Tourist hotspot (La Boca) in Buenos Aires and just around the corner there is a famous Blues Club.
Some friends were playing there and stupidly connected a speaker out to a much needed PA mixer I had made, they blew the first Op Amp (RC4558/TL072) to smithereens.
I had just run out of dual Op Amps, which I planned to resupply on Monday, they were desperate (Musicians always are  :lmao: ) so I fit an LM358 there.
it ..... "worked".
That channel was a little dull compared to others but nothing to write home about.
Crossover distortion must have been measurable but not detected by ear.
Maybe if they were miking a Classic Piano but not in a basic Blues/Rock band!!!!
I told them: "this is an Emergency repair just to save the day, bring it back on Monday for the good one"
Guess what?
They never ever took it back to the shop!
YEARS ago!!!
Now and then I meet them , their answer?
"It works, sound is great for harmonica/harp duty"
Remember there they use those crude Shure Green Bullet taxi dispatcher mikes anyway  :duh
Frequency response not too flat, between 250 Hz and 5 kHz. On a good day  :lmao:
So I suggest you learn how to use Op Amps "by the book" , using the proper NFB networks, both using regular op amps and 358s
Note: many FAKE Hi End Hong Kong/China/EBay Op Amps are actually rebranded dirt cheap 358s  8|
Oh the irony!!!!
Again: they DO "work", although poorly.
I bought an 8 band graphic equalizer for a car that needed a cheap stereo. The thing was full of LM324s ( the quad version of the LM358 ). Each opamp had a 1K resistor from the output to ground. That forces the output stage to run class A instead of class B like the chip was intended. I never tried the chip with or without for comparison but I would hope it makes them sound better.
If you want to experiment with what you have, google "lm358 lm324 projects", you´ll find tons.
Most non Audio but simple light sensors, IR barriers, power supplies, you-name-it.
saturated
Yes sir thanks always great to hear from you  :tu:
I was kinda wondering when it was gonna be mentioned that "why the heck are you playing with LM358  :loco "
Honestly I got them mixed up with LM386  xP
Now I'm having a foray into attempting to comprehend what Mr LT was talking about I think class A means the output never gets clipped and the transistor(s) is always turned on but I'm gonna have to figure out why a 1k resistor causes that  xP
Here in 1994
Things are different than before
Quote from: saturated on November 12, 2026, 01:02:53 PMYes sir thanks always great to hear from you  :tu:
Op Amps are miniature power amps.
They have push pull output, a top NPN transistor and a bottom PNP one.
They MUST have some biasing, or output signal will have ugly crossover distortion.
Here they are NOT biased, zero idle current, remember they are NOT intended for Audio but to, say, amplify the output of a photodiode to trigger an alarm, etc.
A CRUDE solution is to connect a 1k resistor to negative or ground.
This forces top transistor to pass some current all the time (Class A) and makes it "usable", sort of.
Tassieviking
