More low hanging fruit
Started by saturated, October 11, 2026, 09:35:46 PM
saturated
This looks pretty simple but I wanted to try it
I did not find a 7505 but I did have a 7808ct so I hooked it up and went with it
Looks like I forgot about having the capacitor close  xP
And the predictable results (I hope  xP )
It still was an eye opener seeing DC voltage appear at the output before the minimum input level
I wondered if the results might be wacked without a load resistor
Also at the end I felt the metal tab with my hand but it wasn't hot
Next I have to add some resistors and do some more stuff
Hmm now I hope these results agree with the data sheet  xP
Here in 1994
Things are different than before
Those numbers look good.  It will have some output voltage below minimum input spec, it just won't be super consistent and also will be well below your desired 8v output.
saturated
Yes sir thanks always nice to hear from
DA BIG BOSS
  8)
Here in 1994
I guess those low voltages are parasitic/leaks.
You read them only because multimeter has very high impedance.
Try loading output with, say, a 1k resistor and remeasure.
saturated
Yes sir thanks
And the results are in
I did try to feel the resistor and the heat sink tab to see if it was getting warm but not really
Here in 1994
Kaz Kylheku
Yes, a linear regulator isn't something that gives 0V if it is not able to provide its stated voltage. That is a behavior we could design in, but it would actually be unhelpful to downstream devices. Some digital stuff is able to react in a meaningful way when there is a "brownout" or gradual loss of power.
One problem with sharply cutting out (like say outputting 0V any time the input voltage is less than 10V, otherwise outputting 8V) would be that it would turn power supply ripple that crosses the 10V boundary into an 8V square wave, abruptly turning downstream devices on and off. This would briefly happen on every power up and shutdown!
https://www.kylheku.com/mp1https://www.kylheku.com/music-diy
saturated
Yes sir thanks
One thing that bothers me is wondering if it's just a coincidence that they put these voltage regulators in a TO-220 package is that where the similarities end or is there more to it like maybe internally they are the same as a transistor but lacking a component that a transistor would have
Kinda hard to find info on this
Maybe it's just a big zener diode  xP
Here in 1994
Kaz Kylheku
The TO-220 package is probably just chosen for certain heat dissipation: it has a metal tab for screwing to a heat sink and all that. Inside a voltage regulator, there are numerous transistors.  They are all on one piece of silicon. Whether we have a piece of silicion implementing a single TO-220-package transistor or a whole voltage regulator, it doesn't matter to the package.
Packages are deceiving. The ATTiny85 microcontroller is packaged in an 8 pin DIP. It looks exactly like an op-amp. It probably contains on the order of 60,000 transistors.
