There's nothing to be gained from this
Started by saturated, October 03, 2026, 02:56:51 PM
saturated
But I had to take a look
Assuming that a guitar creates a signal with voltage without batteries or power supply I wanted to take a look
Especially since I now have a BNC to phono jack cable hey let's take a look
Now strum (one string only) a bit and try to grab a pic on the scope
The messy "waveform" shown is only one of a myriad of varieties obtained in mere seconds  xP
I can only observe that what comes out of a guitar is much enriched with lots of components and artifacts vs a simple sin wave or something from a generator  xP
Each little harmonic or vibration is probably fighting for survival cancelling each other out and stuff  xP
I then remembered I had a frequency counter from when I was playing with some old CB radios so I thought ok let's see 440 but I didn't manage to get anything useful out of it
Maybe it would help to read the manual
I played whack a mole with all buttons and settings and couldn't come up with anything
Here in 1994
Things are different than before
saturated
Alright well I had thought to try and filter the signal to clean it up and decided to try a series resonant circuit that would only allow 440 to travel through  xP
I knew I had some inductors laying around so I grabbed one that said 15 mH (praying this stands for milli and not micro)
Next I measured it and got 13.24 mH (again praying this is milli and not micro)
With that I cracked open an old book and started looking for the calculation which I found and inserted the value of 440 for f and 0.01324 for H then solved for C not having any idea what number I would come up with.
And I was quite floored with the result
That's pretty crazy that I just need a 10 uf capacitor  xP so I'm damn lucky or damn WRONG
Oh well nothing better to do than hook it up and try
I went back and checked the math ➗
Here in 1994
saturated
So... preliminary results no bueno
I wanted to use an LED as a current indicator so I connected everything and started with a signal generator to see if the LED would come on when I hit the magic frequency
Unfortunately I've got current for days
It's not selective at all
I can go up to 200 khz and the stupid LED stays lit  :grr
Here in 1994
saturated
I removed the LED and hooked up scope probes this circuit is not working
I can change the input frequency to whatever I want and the output shows the exact same thing
I checked the capacitor it checked out 9.66 uf and it's rated for 50v
Back to the ol I wonder what mH stands for
Maybe time to insert micro Henrys into the equation solve for C and try that  :grr
Here in 1994
The output of the generator (one scope probe) should remain the same.  The other scope probe shown should show an AC voltage change across the load resistor, depending on the following:
What is the value of your load resistor?  What is the impedance of your resonant LC combination at resonance?
I think it may be working, just a problem with measurement.
saturated
Yes sir thanks I'm actually sitting outside thinking ok value of randomly selected raistor....brown black red
...should be 1000 ohm  xP
Oh crap maybe I should be measuring CURRENT and not voltage
I'm really interested in the contents of the Boss TU-2 now
xP
Probably extremely silly to thing ok yeah nothing is getting through except the resonant frequency
Here in 1994
saturated
Ok I got it to work somewhat at least there is a definite discernable gaussian brontosaurus 🦕 curve
But it's pathetic actually I read about Q and selectivity and ended up going down to a 1.3 ohm resistor
The top of the curve is only like fifty millivolts ac above the adjacent sides
Why it's not shooting up to the moon 🌙 is a source or torment  :grr
Here in 1994
saturated
#8
I figured it might be time to get some gps coordinates and try to make it back from left field  xP
So I hooked up the signal generator and connected it to the 1.3 ohm resistor (measures 1.7 ohm) and maxed out the output at 500 hz
Makes more sense now
A whopping 0.235 v AC
I guess that's why I didn't get a moonshot
Here in 1994
