There's nothing to be gained from this
Started by saturated, October 03, 2026, 02:56:51 PM
saturated
But I had to take a look
Assuming that a guitar creates a signal with voltage without batteries or power supply I wanted to take a look
Especially since I now have a BNC to phono jack cable hey let's take a look
Now strum (one string only) a bit and try to grab a pic on the scope
The messy "waveform" shown is only one of a myriad of varieties obtained in mere seconds  xP
I can only observe that what comes out of a guitar is much enriched with lots of components and artifacts vs a simple sin wave or something from a generator  xP
Each little harmonic or vibration is probably fighting for survival cancelling each other out and stuff  xP
I then remembered I had a frequency counter from when I was playing with some old CB radios so I thought ok let's see 440 but I didn't manage to get anything useful out of it
Maybe it would help to read the manual
I played whack a mole with all buttons and settings and couldn't come up with anything
Here in 1994
Things are different than before
saturated
Alright well I had thought to try and filter the signal to clean it up and decided to try a series resonant circuit that would only allow 440 to travel through  xP
I knew I had some inductors laying around so I grabbed one that said 15 mH (praying this stands for milli and not micro)
Next I measured it and got 13.24 mH (again praying this is milli and not micro)
With that I cracked open an old book and started looking for the calculation which I found and inserted the value of 440 for f and 0.01324 for H then solved for C not having any idea what number I would come up with.
And I was quite floored with the result
That's pretty crazy that I just need a 10 uf capacitor  xP so I'm damn lucky or damn WRONG
Oh well nothing better to do than hook it up and try
I went back and checked the math ➗
Here in 1994
saturated
So... preliminary results no bueno
I wanted to use an LED as a current indicator so I connected everything and started with a signal generator to see if the LED would come on when I hit the magic frequency
Unfortunately I've got current for days
It's not selective at all
I can go up to 200 khz and the stupid LED stays lit  :grr
Here in 1994
saturated
I removed the LED and hooked up scope probes this circuit is not working
I can change the input frequency to whatever I want and the output shows the exact same thing
I checked the capacitor it checked out 9.66 uf and it's rated for 50v
Back to the ol I wonder what mH stands for
Maybe time to insert micro Henrys into the equation solve for C and try that  :grr
Here in 1994
