yamaha g100 1x12 version 3, amp issue - no sound (sometimes)
Started by mentalmidget, September 22, 2026, 09:20:51 PM
mentalmidget
hi, I bought used yamaha g100 1x12 version 3. sounds great when it works. im having a few issues :
- sometimes, when turning on the amp (it lights up) it either takes a couple mins to start producing sound, or not at all. it'll stay dead silent, then a clicking noise will occur and then its able to start making noise..
- sometimes (usually) it starts producing sound instantly.
- just now, i played for about 5 mins, no issues at first, and then it went silent again. now when i try and turn it on right after, it wont produce sound. this happened before, its like i had to wait a day or at least a few for it to start working again.
not an amp tech at all. no idea what this could be. its like its a loss of power to the preamp section.
https://imgur.com/gallery/yamaha-g100-112-iii-krQQ02U
any tips?
it's an incredible amp. want to fix it.
Kaz Kylheku
The flow of signal through an amp is pretty linear, like a factory assembly line. All of the blocks in the line have to pass signal, or else there is no sound. A no-sound-at-all problem could be anywhere.
If the amp starts passing signal without you banging on it, it looks strongly like a thermal issue. Somewhere there is a bad contact: some kind of mechanical hookup, or a cracked solder joint, or a bad circuit board trace, where a slight thermal expansion improves the contact.
One form of contact that is common in amps is the contact between a potentiometer wiper and the resistive track. Amps have multiple level controls at various gain stages, and if any of those lose contact due to oxidation or contamination, then you get no signal. Next time you fire it up, give every single knob a good spin.
Input jacks can be intermittent, and same with speaker hookups.
Are you able to switch channels? Are both dead at the same time? If so, the problem is in whatever is common between the two: any common preamp path and power amp.
Tapping on things with the eraser end of a pencil can help find a problem like this. Like when the amp is working, and you tap on a certain component and there is a loud crackle or outright relapse into nonworking, then you almost certainly found the culprit. Or vice versa, when it's not working, if tapping on something gets it to work or at least produces a noise.
https://www.kylheku.com/mp1https://www.kylheku.com/music-diy
Another thing that can lead to turn on delays, or random issues, can be defective capacitors.
You said you hear a click when it starts working.  This may be the protection relay engaging.  It should engage right at start up, but sometimes does not, and will sometimes turn on and off at random (rather than when it receives command to protect).
The relay is controlled by IC111, and it is not uncommon that the capacitors in it's circuit go bad.  Those would be C183 thru C186.
Service manual attached.
mentalmidget
thank you. i played the amp yesterday, no issues at all. i dont get it.
Kaz Kylheku
#4
Quote from: mentalmidget on September 24, 2026, 10:08:03 AMthank you. i played the amp yesterday, no issues at all. i dont get it.
Sometimes electrical contacts improve through use. The person who sold the amp might have had it lying around unused.
If it appears to be improving through daily use (you're seeing less and less of the periods of signal dropout) then just keep doing that. If it stops improving before becoming satisfactory, then back to investigation and repair.
I recently got a 2016 Kia Rio, which had mostly nonresponsive cruise control buttons. I thought of opening it to clean out the microswitches, but just by using the buttons everyday, they vastly improved. It is almost 100% reliable now.
I discovered a trick that when the "Set/-" button is not working to initiate cruise, I can hit "Cancel", after which "Set/-" works. This was true even while "Cancel" had not been reliable for its actual job of canceling cruise, though it's working much better now.  The cruise buttons are keyed to a resistor network, creating different voltage levels on a single control line. I think "Cancel" has the lowest resistance, and so most easily discharges a stray gate charge on some CMOS input, helping the next keypress to be read more correctly, or something like that.
Maybe some relay contacts in the amp similarly just need regular exercise?
The previous owner likely disused cruise control. Which kinda makes sense since it's a 6 speed manual. I love cruise, manual or not, but maybe some manual people want to be all manual all the time, gas pedal included.
Another example is the amp that I use for playing guitar. It's a stereo amp but I only use the left channel. The master volume on the opposite channel has totally rotted from disuse. It is horribly intermittent; you have to spin the knob wildly this way and that just to get it to "bite" and pass signal. One day I will wire the cab for stereo and start using that, so I will have to give it some TLC.  However, I think it's going to be coming up to two years pretty soon that I have not used any time-based effects, including reverb! Just distortion. No effects means stereo is pointless.
Tassieviking
Not knowing if you have much experience with electronic repairs or fault finding makes it hard to give advice, one test you should do is check if the headphone output keeps working when the speaker cuts out.
To me it looks like the protection relay disconnects the speaker when it operates but it should not affect the headphone output, if the headphones keep working then do what g1 suggested and replace the capacitors in the protection circuit.
Let us know how it goes please.
Cheers
Mick
Just bridge the FX loop on the back with a short or long mono guitar lead.
It's A very common issue with these loop setups, especially with older amps.
See how it performs then get back to us if no fix.
mentalmidget
i tried that but it didnt work. however the other day i played my amp for about an hour and no issue. havent played it in a few days but.. weird problem
Ok, well points back to the speaker relay and you mentioned it clicks just before you get sound.
This is highly likely either the Relay itself or the circuitry that runs it.
Others here will know more but often you can just bridge the relay terminals and bypass the relay. Outside of rare situations the only real reason for the speaker delay circuitry is to mute the turn on thump through the speaker.
Sadly it looks like you would have to remove the whole PCB to access the terminals
so don't try anything until others here with better experience can verify what I'm saying.
In this case, the relay is also used to when protection circuits are triggered, so it is best to keep it in use rather than bypass it.
It is most likely capacitors in the circuit need replacement, specifically the ones mentioned in post #2.
mentalmidget
Quote from: g1 on October 02, 2026, 12:01:24 PMIn this case, the relay is also used to when protection circuits are triggered, so it is best to keep it in use rather than bypass it.
thanks for your help..
https://imgur.com/gallery/yamaha-g100-112-iii-burnt-capacitor-MRPKIYX
i think its the cap thats at 2p 390. theres some heat coming off of that area, so much that it makes the cap loose after a few mins. also IC113 gets hot, probably from the cap. hoping i can just replace the cap. Are you able to determine the value of the cap? i could look it up but i'd like to double check with you if you dont mind. unless you think i should replace IC113 as well?
edit : burnt resistor... 2 pin 390 ohms.
edit : yesterday the amp wouldn't make a sound, like the relay wouldn't make a clicking sound, guessing because the resistor was prongs were melted, not sure. today the amp works fine, the resistor never loosened after awhile, but IC113 the voltage regulator was still hot. i'd like to remove the PCB and look underneath to see if i can notice any burns spots. but i'm wondering if its just a faulty voltage regulator?
The 390R resistor is supposed to run hot, it supplies current to the relay coil, that is why it is a higher wattage component than a lot of the smaller ones.  Measure it to see if it has changed value, it is probably still in spec. If it has drifted out of spec., replace it and raise the new one off the board a bit so it can dissipate heat better.
The heat from that resistor may be part of the reason the caps in that circuit go bad.  Replace them.
mentalmidget
so yesterday the amp didnt work at all. today no issues. i believe the resistor is fine actually, but the voltage regulator gives off a ton of heat (compared to the other voltage regulators). this issue is intermittent though, not sure why the amp would work fine one day and not the next.
however yesterday i noticed the resistor in question was loose at its solder joints and perhaps disconnected, probably from the heat of the voltage regulator? today though , even after the amps been on awhile, the resistor was seated firmly in place, not loose.
is it a bad voltage regulator? or something else? i apologize for all the qeustions
Well sounds like you have a cracked solder joint on the 390 resistor which is intermittently connecting
Yes you will need to resolder it, better still (as G1 mentioned)replace it and lift it off the pcb which will reduce the heat transfer back down to the solder pad. (also bend it away from the regulator will help)
Cracked solder pads are Caused by the constant thermal cycling which fatigues the solder.
I think I've been looking at the wrong Schematic, I just found the right one, yay
Yes the Regulators do get hot hence the heat sinks are added.
mentalmidget
Quote from: phatt on Today at 07:45:00 PMWell sounds like you have a cracked solder joint on the 390 resistor which is intermittently connecting
thanks. the issue is the resistor solder joints were loose yesterday and the amp wouldnt work. today the resistor was firmly seated and the amp worked fine. also the voltage regulator 113 was significantly hotter than the other 2 or 3 around it.
my question is, could a bad relay that doesnt engage cause the buildup of heat at the voltage regulator/resistor? today the relay was engaging every time i turned the amp on though, so no issues today. but maybe some days it doesnt work? i dont know.
