Sunn coliseum 300 pre amp trouble
Started by pontiacpete, August 29, 2026, 11:07:02 AM
pontiacpete
I am tracing through the pre amp and finding that the signal stops at IC5 SSM2012a. I could  be wrong about this but it looks like this chip is bad. Since these are long unavailable what are people doing for a substitute?
The schematic is :
https://www.prowessamplifiers.com/schematics/images/Coliseum_300_11_x_17.pdf
It might be wrong of course, but remember SSM2012/13 are current output ICs, so scope who reads voltages only can show "no signal" there.
Try output of Next op amp, pin 7 of IC6b.
From what I read modern substitutes are certain THAT ICs but are not pin compatible and require redesigning.
MAYBE the Synthesizer guys make a replacement board based on modern stuff. Remember Peavey made a replacement board for their obsolete analog switching chip.
pontiacpete
Unfortunately there is no signal on IC6b. Pin 5 and 6 just a flat line and pin 7 has a small wiggly line.
Is that it for this amp unless I can fit another chip in place of IC5?
Absolute worst case, IF your amp is muted AND you need it NOW for a tour, a rehearsal studio, etc. you can fully bypass the compressor section by lifting the right leg of C1, the left leg of C7 and joining them with a piece of wire.
Amp will work fine, except compressor.
Right or left as seen on schematic,  they can point anywhere on PCB
pontiacpete
Yes, you may also have other problems.
Is this from a standard customer so limited on how much time/money can you spend on it, or is it yours or with sentimental value which merits extra?
N
Because you can build a gain cell replacement with modern ICs, THAT or others, but it will require protoboarding it to be safe, designing and building a small PCB or maybe on Veroboard but that still requires creating a Vero layout.
This is THAT 4305 block diagram.
As you see, it is functionally equivalent to yours.
Top half is the gain cell, basically same: input signal through a 20k (24k in Sunn) resistor, gain cell proper, signal current output converted back to voltage in an Op Amp 20k NFB instead of 24k.
MAYBE you could make them pin compatible using a mini board, because modern is SMD.
Maybe you still use the original RMS rectifier , not sure whether control voltage generated is proper level or polarity but a single Op Amp can take care of that.
When amp works, inject signal and move threshold pot around, measure what is being generated and sent to SSM pin 9.
There is a control voltage pin: Ec-
pontiacpete
This amp belongs to a customer. A year ago I replaced the output transistors and fan, and he says it has worked great until this issue arose. I don't know how much more he wants to put into it but I did order the new ssm2013. If this works I think it will be reasonable enough for him.
So, I went and did the jumping over that chip, disconnected at C1 and C7 and I'm still not getting sound. This seems strange that nothing is coming out  but I'll have another look at it today to see if I did it right
Kaz Kylheku
Quote from: pontiacpete on August 31, 2026, 08:24:58 AMSo, I went and did the jumping over that chip, disconnected at C1 and C7 and I'm still not getting sound. ... I'll have another look at it today to see if I did it right
Yeah, double check that you're bridging the correct pad of C1 to the correct pad of C7.
https://www.kylheku.com/mp1https://www.kylheku.com/music-diy
pontiacpete
This is what I did, I lifted c1 where it meets r2 then connected to the free leg of c1 that was lifted. Then I lifted c7 where it meets with ic6 pin7 and connected to the c7 freed leg. Does this sound correct?
Kaz Kylheku
Quote from: pontiacpete on August 31, 2026, 06:10:35 PMThis is what I did, I lifted c1 where it meets r2 then connected to the free leg of c1 that was lifted. Then I lifted c7 where it meets with ic6 pin7 and connected to the c7 freed leg. Does this sound correct?
It does sound correct. Both capacitors are included in the patch, in series, so it is like a single cap of around 0.45 uF. If the driving op-amp is making signal, it should go around IC5 and to the "contour" block's IC1A, if the caps are good. See if toggling that contour bypass switch makes any difference.
pontiacpete
Toggling the 'contour ' doesn't do anything
Just for clarity:
you joined C1 right leg "in the air" to C7 left leg, again in the air?
If you inject audio at input, do you have signal at that wire?
Does that signal appear in "contour" IC1a pin?
If so, does it appear on all 3 pins of Contour switch?
Toggle it repeatedly, after some Deoxit squirting.
We still don´t know where signal is being lost.
pontiacpete
I guess I didn't understand how IC5 functions. And I still don't. I was checking for signal on pins 13 and 4 on IC5 and there was nothing. Now I see there is signal on pin7 of IC6b. How is that possible?
I clearly don't know the signal path. There is signal on the top side of the Zener D1 but nothing on the other side of D2. Should I see signal of both sides of the diodes when the 'contour' switch is off?
I will trace from IC6 with the compressor on. At this point I'm not sure where it goes when it's off.
Sorry about this.
Scopes see voltages.
IC5 is a current amplifier, no voltages to see.
Since we usually work with voltages, we must be able to convert one into the other.
Here:
Audio voltage present at left of R2 gets converted to current thanks to R24 which is injected into IC5 pin 13
Say you have 1 V RMS , it gets converted into 1 V/24k = 0,042 mA
IC5 outputs 0.042 mA into pin 6 of IC6B which converts it back into 1V RMS.
If you get signal there, then you DO have functioning IC5 and OC6 so replace nothing.
The whole circuit block between C1 and C7 is a unity voltage gain stage, that´s why I suggested replacing it with a piece of wire for testing.
That with zero voltage control injected on IC5 pin 9, that´s why grounding it with "compression" switch turns compression OFF
To make compression work, you have a "perfect" rectifier built around IC2a and IC3a-b into IC4b.
Here again positive rectified voltages become positive currents into IC4b pin 6 thanks to R22/23
Now IC4b turns that positive current into a negative voltage which gets applied to IC5 pin 9
My educated guess is that IC5designers (same as modern THAD IC) found a way to Gain control using currents
Musical instrument compressors are way simpler, usually through a LED/LDR or FET or even a humble bipolar transistor or Diode, this is a Studio Quality compressor.
Bet SUNN designers just took the short path and adapted it to a Musical Instrument amp.
Just check a Boss or MXR or DOD pedal compressor.
Or a Crate/Ampeg optical one.
