I'm bored (DIY oscillator)
Started by saturated, August 04, 2026, 09:07:55 PM
saturated
Btw sitting here doing some thinking
The circuit that worked utilized capacitors 100x smaller than what I tried  xP
And the resistors that I tried were orders of magnitude larger  xP
So going back to the original generic schematic that I could not get to work....it used the polarized capacitor symbol so hence I used electrolytic capacitors in my trial runs.
Also referring back to the schematic for the tube generator and I presume MFD means microfarads but idk
But it could be that there's no reason to compare the two (SS vs tube) because they are completely different animals
At any rate I may try using the smaller capacitors and resistors and see if it works
The protagonist is deeply entrenched in curses from Satan and fights his inner demons to free himself from the curses that plague him.
saturated
So the original generic configuration that was attempted I made a big reduction in values for resistors and capacitors
Increasing the power supply slowly I noticed there was something that rapidly appeared and disappeared as voltage continued to increase
So I went back to the narrow range where it would appear and carefully dialed it in and got this
What's wierd is if I decrease voltage the frequency decreases and if I increase voltage the frequency increases  xP
Because it was bugging me that amplitude was not responding to voltage level  :grr
Before I shut it down I decided to write down some voltages
The first set is taken when there was the visible waveform or apparition or more likely abberation  xP
Then below that is when the voltage was increased to cause the abomination  xP to collapse and become a straight line
Hmm looking at this I don't think the base is supposed to be more positive than the collector but I'm not sure
Maybe I need to increase the Q1 base resistor
