I'm bored (DIY oscillator)
Started by saturated, August 04, 2026, 09:07:55 PM
saturated
Gonna try to make an oscillator based on this
I have no idea what values of resistors or capacitors to use
Nor do I even know what where the output is
I presume B+ is gonna be DC piped in to two places
Anyhow I looked in my box of junk and pulled out two ancient transistors hoping they were NPN and they are
Should be cool 😎
The protagonist is deeply entrenched in curses from Satan and fights his inner demons to free himself from the curses that plague him.
Did it work?
saturated
I just assembled this rats nest
Not knowing where to put the scope probe I attached it to the positive leg of C1
And it looks like the sum of all those randomly selected components has resulted in a malfunctioning diode
That being said hey I'm glad I got something
Maybe that "waveform" can tell me something  xP
saturated
So the only cheating I did was glancing at the tube oscillator schematic  xP
I noticed they were using much smaller capacitors
So I changed out the two 100 uf for 22 uf and played musical resistors for a while really no change but a cleaner rectified waveform  xP
I have decent Vbe on each transistor 0.7 and 0.65
Also voltage across the resistors going to ground  xP
So idk should be educational  :tu:
saturated
#4
So I'm gonna make some BOLD statements here
Some (or all) of them probably wrong
I think it's worth stating that we need the collector of each transistor more positive than the base and the emitter
Since the base of (call it) Q1 and the collector of Q1 get their voltage from the same place then I'm gonna say that R3 needs to drop less voltage so the collector will have more voltage leftover therefore R3<R1
Now looking at Q2 it's collector gets straight up B+ so of course whatever value R4 is the collector of Q1 will be more positive.
But I'm sure it's important what the value is I just don't know  xP
And then I think we are good to go with the emitters since they both are at ground ok maybe not I have no idea what values those emitter resistors should be seems like I remember people liked to have em there because it made the circuit more stable.
Btw my condolences to anyone suffering through this i just didn't want to get some premade recipe online or YouTube  xP
With that I think I'll meditate trying to see what kind of voltage I need on the base(s)
saturated
Ok time to start keeping records and analyzing results
First I redrew the circuit trying to make it easier to comprehend  xP
Then rolled out another configuration
I feel a fusillade of erasers bouncing off my head as I report this because I should know what it means when an emitter has the same voltage as the collector (I think it means the transistor is in saturation mode).  xP
Anyhow I'm gonna stick with CHANGING ONE THING AT A TIME so I don't induce myself or anyone reading this into despair  xP  :loco
saturated
#6
Ugh ok nm
Just looked in some of my books and apparently saturation mode is the max collector current
And I have a bit of a voltage drop across the first collector resistor but hardly nada on the second
Oh well this is cool because it's making me have to think about stuff  :lmao:
And whoops
How does a direct short from B+ to the base of Q2 result in a 1.5V drop
Doh 😣
From the looks of your re-drawn schematic, you have moved the resistor from the 'Q2' base to it's collector.  We have no emoji for the 'shame shame' gesture we do with our index fingers.   :lmao:
saturated
#8
Ugh
Yeah I know I literally just discovered that
Ok another revision
Which I already don't like because there is no collector resistor on Q2  :'(
Look up 'common collector' or 'emitter follower' circuit.
saturated
Ugh ok here we go
I'm gonna try to do this like I'm at a job interview or something
I know or think common emitter means the emitter is connected to the ground of the input voltage as well as the output measured voltage
And cathode means emitter
So dude where's my sin waves  xP
Quote from: saturated on August 04, 2026, 09:07:55 PMGonna try to make an oscillator based on this
Should be cool 😎
That one might be a relaxation oscillator, turning out a weird unsymmetrical "square wave".
For a sine wave oscillators you need THREE capacitors and resistors, like on tremolo oscillators
For the full article:
https://circuitdigest.com/electronic-circuits/sine-wave-generator-circuit Sinewave will probably clip a little on one or both peaks because there“s an excess of gain to guarantee it starts oscillating but is good enough.
Do the experiment, they even show a protoboard version, and post results.
Kaz Kylheku
That oscillator looks exactly like someone trying to build a two-stage amp, which ends up motorboating or otherwise oscillating. R2 and R5 represent the parasitic resistances due to bad grounding practices.  :lmao:
C2 could be a parasitic capacitance between two long, parallel traces.
https://www.kylheku.com/mp1https://www.kylheku.com/music-diy
