Just when you thought it was safe to go back to the Noobie section
Started by saturated, July 29, 2026, 08:55:38 PM
saturated
I texted my friend with the junk store and told him I was ready to do some more shopping.  As in deep dive flashlight 🔦 in hand.  110f be damned.  xP
He said he is still shut down by the fire chief and as much as I love him I am disappointed that he hasn't really gotten rid of anything  :grr
Anyhow I remembered I actually do have something that needs work only I wasn't too interested in working on it then it dawned on me that the Big Boys here work on lots of stuff that they don't want to but took the electronic Hippocratic oath  xP and well it's time for me to not judge equipment just get on with it.
So I present to you the RCA WA-44C Audio Generator
Fear not it's been inspected and deemed good to go
I'm leery of this because I'm pretty sure it has tubes (high voltage) inside
So first order of the day check out on DBT
Seems to be ok that bulb is not near as bright as it looks
Next I started twiddling and checking for output which I could not get any.
However the line frequency seems operational
So maybe time to get a schematic and looking over it for places to take voltage readings
 xP
I'll admit one problem I have is trouble determining if something actually is not working so perhaps I should attach some scope probes to the variable frequency output  :grr
The protagonist is deeply entrenched in curses from Satan and fights his inner demons to free himself from the curses that plague him.
saturated
Wow looks nice
I wonder what that light bulb is supposed to do
:grr
saturated
A few notes here  :loco
Looks like the "line frequency" is easy enough it's just some transformer secondaries I presume routed through a potentiometer  xP
As far as the rest of the unit it's SOP that nothing will be touched/desoldered/damaged/mutilated/removed without overwhelming evidence 🧾 of guilt.
All components will be presumed innocent  :grr
I was wondering what the weird red diodes were but they look like insulated jumpers  :tu:
The schematic looks simple enough maybe I can handle this  :lmao:
Something I am intrigued by is the concept of "open capacitor"  xP
When I first read about this i thought well of course every capacitor is "open" as in it will not pass DC unless it leaks
But now I think what they mean is there are faulty capacitors which will not pass signal/waveforms/AC etc
So now I may try seeing if some of these capacitors will pass signal in circuit which may be a primrose path kinda like testing resistors in circuit  :grr
Also I kind of wondering what's in that metal box section that looks like a doghouse in tube amps  xP
saturated
Well I actually have a plan
Upon perusal of the schematic I have learned that there is a 6X4 full wave rectifier tube that uses 6.3V heater
So that's what I'm gonna take some measurements on
You are correct about an 'open' cap.  It won't allow signal through when used as a coupling cap, and it won't do any filtering when used as a filter cap; it just acts like nothing is there and will not hold any charge.
The metal doghouse is where they keep filter caps in  the Fender classic tube amps, but is also sometimes used for shielding.  In this case I would guess there is a big tuning capacitor in there that is being shielded.
Can you post schematic?
saturated
Yes sir thanks
Too funny I'm sitting here in my bronco sweating buckets at my daughter's graduation can't leave because the parking lot is full of cars in line going nowhere
Edit
https://radiomanual.info/schemi/ACC_instrument/RCA_WA-44C_audio_generator_user_1966.pdf
Still trying to download just the two pages of the schematic
saturated
So either fortunately or unfortunately I don't seem to see a problem with the beginning stages of the power supply
(It was impossible to get at pin 7 of the 6x4 tube so I measured at the junction if the trace from it going to (what I presume) was L1
Then I measured both sides of R19
So the search continues  xP
saturated
Also as a NOOB I'm getting to where if I cant clip a lead on to whatever I'm measuring I just don't trust it  :grr
I know that's not always possible but that's the case for me  :'(
saturated
One last set of measurements after a busy day
Probing V2 a 6AQ5 tube
Results seem (to me) to be in somewhat agreement with the schematic
Kinda early in the game but I'm wondering now if we aren't dealing yet again with a dirty switch somewhere  :grr
saturated
This has been a pretty interesting project so far.
I was wondering about that light bulb 💡 and no I don't understand it but it has to do with gain and feedback and regeneration and possibly a guy named Larned Ames Meacham and HP 201s
Apparently it acts as a temperature dependent resistor  xP
I actually wondered if it was used to set bias or something like maybe the manual would instruct the user to turn a potentiometer until the bulb lit or went out
I checked it it has IIRC about 428 ohms at room temp
So the manual says it's a bridged T circuit so I'm headed off down a rabbit 🐰 hole maybe I need to build one of these circuits out of solid state components and get familiar with its principles of operation  xP
I think this unit has a ground problem seems like there is about 8v AC on the chassis.
 :grr
saturated
So I was looking this over at work getting in a pickle wondering what the heck
The schematic shows two V1 tubes  :grr
And I could only find one
Well I may look and sound like an idiot but let there be no doubt ....I am an idiot  :dbtu:
Just to help possibly the Pros try to get an insight into the disturbing mind of the noob
I finally figured out that yes there is in fact only ONE V1 the schematic is indicating two different configurations
So now that I (think) I am past that I think I'm gonna find every resistor going to ground on the schematic and and test resistance
saturated
Some results
The last resistors I couldn't find but the others seem to check out
Then checking V1 in B mode I possibly found the first anomaly
So it's cool that I may have found something but would it cause it to have no output idk gonna have to check into this
Meanwhile need to probe the other tube  xP
Kaz Kylheku
Sounds like the light bulb is part of a Wien bridge oscillator type circuit. The bulb acts as a positive-temperature-coefficient thermistor which helps the circuit have high gain on power-up to help start the oscillation, but then to limit the gain.
https://www.kylheku.com/mp1https://www.kylheku.com/music-diy
saturated
The results for V3 are in
One thing I'm noticing is all my DC measurements take a while I have to sit there until they go from mV to a stable reading
Also I need to learn how to zoom in part of a schematic and make an image out of it  :grr
