The return of PACO
Started by saturated, July 08, 2026, 12:54:59 PM
saturated
He's back  xP
Time to do some exercises
 xP
I ask stupid questions
and make stupid mistakes
saturated
A baffling experience was recorded today  :-X
Using a multimeter where you have to select the range the resistance of a forward biased diode was about 3.3 Mohm and infinite reverse biased
Then using the diode function the typical forward voltage drop was obtained without incident.
So what's the beef  :grr well the auto ranging multimeter showed infinite resistance when forward biased and a few megohm when reverse biased  :lmao: (and it has no diode test function)
 :loco
saturated
I went back and rechecked all my results and even added a couple other multimeters to the mix
Gonna have to think about this one for a while  xP
Set the Ideal or the Centech to measure DC volts.
Check the polarity (and voltage) of the DC being put out by the Amprobe's when they are set to ohms or diode check functions.
saturated
I now see that this perceived "problem" is mere child's play for the Mighty G1  :dbtu:
 :tu:
