The return of PACO
Started by saturated, July 08, 2026, 12:54:59 PM
saturated
Yes sir thanks I believe you but that's kinda outa my pay grade  xP
Anyhow I'm digging out another transformer because I need one with a center tap for the dual wave rectifier  :tu:
Here in 1994
Quote from: saturated on July 15, 2026, 01:15:21 PMThanks guys sorry I should have mentioned when I tried the 208 and 240 NO VARIAC
Then I expect the 16V secondary voltage you measured was the correct one when applying 120V to the 208V primary winding.  The 3V reading will have been some kind of error.
You don´t know what wire gauge/thickness was used to wind that transformer.
THERE IS an optimum value achieved by calculation but winder uses what´s available, so sometimes not optimum.
Or wire simply can´t fit within EI window, same thing.
