Pedal resources
Started by smsuryan, June 04, 2026, 09:34:45 PM
smsuryan
Before I dive into making even a small amp, I estimate that making a pedal is a worthwhile pursuit.
I'm sure there are "premade kits", but what is a resource/company/website you would recommend for the box?
I have a pile of resistors and capacitors in a few bulk buys that I've used for guitars (amplified parts.com), I not only build/service guitars for myself but also for charity:a local music class with lots of kids who come from families who are broke! I build between 5-10 a year, usually. The class itself received in total, 45 last year.
Most of these kids plug into whatever amps are available at class, but I'd like to build some type of pedal to be able to plug into something with a speaker and a power supply.
It might not be an amp, but I'd also just like to build one for myself. The only pedal I ever really use is a 10 band EQ going into my amp. The caps and resistors I have are for guitars, I'm sure I can use some of them for a pedal, but I'll for sure need way more that are amp/pedal specific, I have output/input jacks, and random parts, but a list and a source would be nice. And I'm really not sure what kind of pedal. Distortion, reverb, flange, chorus, just anything to get my feet wet. Suggestions and recommendations welcome. Thanks guys!
Tassieviking
I get my boxes from Tayda electronics, they can drill them and paint them for you as well if you give them the drill files and paint files.
The last few years I have mainly been making pedals with tubes in them that C2CE makes and sells the PCB's for, they also have drill files and paint files you can use to send to Tayda so they make the boxes up for the pedals.
https://www.taydaelectronics.com/
https://c2celectronics.com/
smsuryan
Thanks for the feedback. Which pedals are more difficult to make, with tubes or without? Or is there a significant difference at all?
Tassieviking
Tube pedals can be a lot more dangerous, all the C2CE pedals have high voltage inside them even though they run on 9v-12v. I think all the C2CE pedals have between 240v to 300v inside them. The owner of C2CE also runs Sushi Box FX which makes pre made pedals that all have tubes and they can run up to 360volts on the internal tubes just like a real tube amp.
If looking at doing it all on your own, check out the designs at runoffgroove.com.  If you want to get a kit, you can get them all over the internet, but stewmac.com has some good ones that have really good reviews.
