DIY Discrete Solid State Guitar Amp
Started by branko_76, June 03, 2026, 11:28:06 AM
branko_76
I'm relatively new to electronics so would like to use this as a learning project. I've restored a number of early transistor & tube audio amps and one SS guitar amp. Have dmm, oscilloscope, sg, soldering station, etc.
Are there any amps out there I can clone or are there any tried and true schematics available that I can use?
My goals are:
all discrete circuit (no op-amps, IC's, etc.)
10-20 watts (+-)
treble & bass controls
capacitor coupled output
thanks in advance
aquataur
From your words I deduce that you want to build a musical instrument amplifier, not a HiFi unit.
10 Watts is nothing for a MI amplifier. Although the power itself is not the restriction, it is the lack of headroom.
SS amps clipped sound awful. A 10W tube amp can create the appearance of being of much higher wattage due to the compression and benign clipping, which most of the time goes unnoticed.
Your description fits SS amplifiers from the past, such as early John Linsley-Hood class-A designs. He was designing for HiFi, and even he, at a later time, went to higher wattage push-pull designs.
You create the impression of believing that discrete design is less demanding - it is not. In fact the contrary is the case, worsened by the fact that op-amp design is better understood today than discrete.
Schematics are around, but be aware that this is only half the story. PCB and other layout is ultra critical with power amps. The components reach up into the MHz range, and they can and will oscillate vigorously if you are not experienced, most time leading to immediate self-destruction. This can hinge on simple things like two tracks running in parallel for a length. This reaches deeply into HF design, where other rules apply, and they are not forgiving.
For a newcomer into that field, this is a very ambitious endeavor.
If you are determined, be at least prepared for harsh set-backs.
branko_76
Thanks for the response.
Yes, I would like to build a guitar amp. What inspired me was an old Univox SS amp I found recently, it has all of the attributes I mentioned except it has a "tone" control and I would like separate bass and treble. I suppose I could build a clone of it (I have the schematic) but would like some options.
branko_76
Quote from: aquataur on June 04, 2026, 03:20:35 AMYou create the impression of believing that discrete design is less demanding - it is not. In fact the contrary is the case, worsened by the fact that op-amp design is better understood today than discrete.
I don't have the impression that discrete design is less demanding. I'm interested in learning how amplifiers work and how the components interact with each other.
The only assumption I have is that opamps or IC's do the work of numerous discrete components. I would like to have a better understanding of basic electronic circuits.
aquataur
I have seen it expressed by some fellow (somewhere in the jungle of boards and threads...) that they stay away from discrete circuits, because they grew up with OPAs... That's that excluded anyway.
QuoteI'm interested in learning how amplifiers work and how the components interact with each other.
Well that's a noble approach and a good propellant.
Just saying, that power amplifiers have a side to them, which a normal pedal tinkerer hardly ever crosses into - HF. And also, since comparably  huge current flows are involved, low frequency issues - speak: hum.
Many of the layouts of stompbox PCBs I see on forae are showcase. You can tell that immediately by cosmetically beautiful component placement and by ground planes that flood everything with the totally wrong assumption, that this helps.
With a stomp box, you get away with murder, but a PCB for a power amp is unforgiving. Been there, done that.
This is certainly several levels above stomp boxes.
Except for a few "utilitarian" stomp boxes that I bought kits for, I have always made my PCBs by myself. The were never as posh, but they are quieter, to name one thing. There is lots and lots you can learn from that.
You certainly will choose the right path, and I wish you the best for it.
branko_76
So you don't have any suggestions, just a lecture?
The title of this particular forum is: "The Newcomer's Forum"...am I in the wrong place?
aquataur
Right. So you seem determined.
For designing amps, there is several books that I can recommend.
My starter book was from London Power (Kevin O´Connor), TUT2. You have to buy it.
There is also a book by Merlin, Designing Valve Preamps For Guitar And Bass. An early version is available for download. Chapter 12 talks about grounding, since I mentioned that to be of prime importance. I presume it is OK by Merlin, otherwise he would have taken it down.
Although these books are about tubes, the underlying principles are universally valid.
There is also a ton of information available from Rod Elliott.
Those are cook-book guidelines for a tough matter. It does not get simple.
Thanks for coming here - I'm always glad to have a new face and I love the idea of building a fully discrete practice amp.  I've had thoughts to do the same myself and haven't had a chance to do so yet.
Honestly, this isn't nearly as large a task as it seems.  For the preamp side of things, you can use any discrete pedal amp circuit that you like the sound of.  You can either keep it as-is, or find one you want to modify.  Something like Jack Orman's Mosfet Booster, RunOffGroove's Peppermill, or even my 5th Gear Overdrive would make a good gain stage.
You could make the booster for the initial input, go into a tonestack of your choosing (see Duncan TSC in the web for ideas), then go into another gain stage for recovery and drive (like the 5th gear OD).
After the preamp is complete, you could send it into an amp from Rod Eliot, like his project 10 - a 20w Class A discrete amplifier.
Whatever options you choose, definitely come back and let us know how it goes or if you need help!
branko_76
That's awesome, thank you. I've considered building a class A for audio, didn't know it could work for guitar as well.
So, is it safe to say that the main difference between guitar and audio amps is in the "preamp" section?
Quote from: branko_76 on June 10, 2026, 12:01:27 AMThat's awesome, thank you. I've considered building a class A for audio, didn't know it could work for guitar as well.
It certainly can be the main difference, and nowadays I would say "yes".  In older, and current tube design, amplifiers - no.  Older guitar amps would have "sag" in the power amplifier section, particularly in tube amps.  This creates a significant amount of compression and a certain sound of distortion.  Current amps all basically use a super clean power amp (like you would for hifi use) and get all the distortion, compression, etc from the preamp section.
Check the schematic in post #7 of this thread:
https://www.ssguitar.com/index.php?topic=3747.msg29227#msg29227
It uses just enough feedback to set the DC operating point. Softly clips when the output gets near the rails. Gain is about 100 so it can be driven by a stomp box.
I forgot to add the Randall RG100 power amp. At first look it's pretty normal, but it's really a current output (very high output impedance) amplifier. You can find the schematic on this site, search for RG100.
Quote from: Loudthud on June 14, 2026, 10:50:57 PMCheck the schematic in post #7 of this thread:
What kind of output would you expect into a 4, 8, or 16 ohm load from this?
