30W power am design (from Crafter DSP1 schematic)
Started by Synctime, April 12, 2026, 10:54:48 AM
Synctime
Attached is the power amp portion of the Crafter DSP-1 30W guitar amplifier.
It's an unusual design, as there's a long tail pair at the input. One input is the signal input and the other input is a compensated/equalised signal from the speaker output. I guess the latter is to balance the enclosure, but I suspect it's also providing positive feedback that amplifies the low frequency which is creating a constant 50Hz hum at the output. Am I right or wrong? Please advise.
I haven't opened the amp to investigate the source/cause of the  hum yet. It seems that it's a common problem with this Crafter amp because another one currently listed ebay UK has the same fault/problem. I am thinking of modifying the inout circuitry into a single input one without feedback, ie the classical design, or replace the entire power amp with a Class D mudule. Thoughts anybody?
#1
The way I interpret the speaker outputs signal return back to input, as a type of negative feedback. Thus reducing the signal upon itself using an inverted out of phase signal. In PA systems each gain stage is filled with negative feedback to keep the signal stable and less distortion. Well that's just a thought I had looking at this. I see where it might be positive feedback but I am pretty sure that the signal is phase-inverted which cancels out the source signal. To make the signal in phase with the source input signal would be positive feedback. I am guessing that would make the signals a tiny bit time delayed, milliseconds. Hence you delay the positive feedback more and more you can create a chorus effect from the two signals.
Synctime
I agree it's negative feedback, with some equalisation. I just couldn't figure out here the constant amplitude 50Hz hum is coming. It's present even with the input disconnect from the pre-amp output.
Maybe it's gain is too high, and it's picking up EMC from the transformer.
Usually power amps have low gain, no feedback, and no equalisation, so I am baffled by this design.
Any kind of ground issue or ground loop will give you 50Hz hum, so a poor ground scheme could also be the source of your hum.
Quote from: Synctime on April 12, 2026, 10:54:48 AMAttached is the power amp portion of the Crafter DSP-1 30W guitar amplifier.
Not unusual at all, it´s the MOST common SS power amp design, invented by Lin in the late 50s and used everywhere since the 60s.
ALL Peavey Fender Marshall Crate etc. power amps are like that.
It has a differential pair at the input, constantly comparing input signal with speaker out, and correcting whatever´s needed.
A "giant Op Amp"
You most probably have a grounding problem. Hard to solve because Ground is not "real" ground, often it is "dirty".
Best I can suggest is you lift C49 leg which is connected to ground and connect it with a short piece of wire to the grounded pad for R60 so both use same ground.
Try it, and post results.
woodman
The Crafter amp hum problem is the circuit board design. I cured the common hum problem by modifying the pcb. The Dc smoothing capacitors are joined by a copper track to form the ground between plus and minus rails and several ground points join this copper strip. This track carries the ripple current for the smoothing capacitors and should be joined at a single point to effectivly produce a star earth point. The solution is to cut the ground track on the negative capacitor, and with a decent thickness of copper wire join the positive terminal of the negative supply capacitor to the ground of the positive supply. This produces a star ground and the supply ripple current terminates at the same point. This reduces the standing background hum by over 20db. I did a couple of other changes to the circuit -- changed the gain low frequency gain cap (C49) for a non polar device and the bootstrap capacitor C60 for a low leakage type.
Good luck fixing this nice little amp.
Kaz Kylheku
Quote from: woodman on October 29, 2026, 06:58:16 AMI cured the common hum problem by modifying the pcb.
Good work! I'm guessing that the issue is that the copper track you bypassed that handles the grounding of the filter cap ripple currents is shared with with the grounding of sensitive downstream circuits. I.e. any voltage produced on that piece of copper tracks is seen by those circuits because their ground is referenced back to that copper track where that ripple voltage is being induced.
https://www.kylheku.com/mp1https://www.kylheku.com/music-diy
