November 18, 2025, 12:00:22 PM
Faulty multimeter
Started by saturated, November 15, 2025, 09:03:39 PM
saturated
Picked up this multimeter known to be not working
Had no display whatsoever
Hoped it was a dead battery  :tu:
Opened it up.  No battery  :tu:
Installed new battery....only display on certain modes.   :grr
Checked internal $30 fuse.  Open  :grr
Installed new fuse.  Fingers crossed.  No change  :grr
Connected mini-grabbers and 150 ohm resistor
Continuity mode.  Nothing
200 ohm range
Working
2000 ohm range
Working
20,000 ohm range
Working
200 kohm range
Back to nothing  :grr
Not really equipped to diagnose or repair tiny surface mount stuff.
I ask stupid questions
and make stupid mistakes
I would see if you can verify switch contacts for bad ranges/functions.
TomCarlos
Quote from: g1 on November 16, 2025, 10:46:16 AMI would see if you can verify switch contacts for bad ranges/functions.
Agree with G1.  I had a similar issue to a meter.  The dial is connected to a circular metallic gizmo that turns and makes connections to points on a circuit board.  That metallic gizmo was dirty and had slightly deformed.  So I bent it here, bent it there, reassembled and voila, the meter and functions came back to life.  Make sure you also use some spray cleaner on all contacts and pots.
saturated
Thanks guys I appreciate it and like anything I'm working on it's not a big deal but at the same time I don't take your help lightly  :dbtu:
Anyhow I did some more disassembly and didn't really find any 🚭 smoking 🚬 guns
Which was a good thing I guess but still at square one.
So I put it all back together and no change  :grr
saturated
Meanwhile I really wanted to get the full size circuit board out so I was like dude just take it apart again and keep going  :grr
So I noticed I would not be able to get the full size board out with the contact selector wheel in place but I didn't know how to get it off. So I tugged gently on the front of the meter and no go.  :grr
Then I pulled from the backside and wow  :loco  xP  :'(  :lmao:  :tu:
Houston we have a problem  :trouble
I do not know what happened I had suspected it had gotten wet.  Or ended up in the drink idk 🚢⛵
But now that I look at it I wonder if that is burn marks  :grr
I could clean it up but as you can see one of those copper pieces is all mangled.
Anyhow thanks guys that was definitely interesting  :dbtu:
saturated
I cleaned everything up real good and removed that mangled contact
I figured I would hopefully gain a few more functions but NO  :grr
Now it has less functions I lost the low resistance range.
Yes I know that piece 🧩 is necessary but I think it's more necessary than I thought
So now I have to try to find a replacement piece or fab something up (yeah right  :lmao:  xP  :loco )
Or just send it to the factory for service  :'(
But yeah you guys nailed it for sure  :lmao:
Thanks again
Does the board clean up where those contacts meet?  It looks like some of the traces may be ground down.  If not, and the board is ok, you should be able to buy that actuator wheel with the contacts attached.
