October 30, 2025, 11:32:01 PM
48v Phantom Power Supply For Direct Box
Started by TomCarlos, October 29, 2025, 10:43:05 PM
TomCarlos
Forum Members....
I have a Radial Pro48 Active Direct Box (non-powered) and would like to take the XLR output into a mixer.  The mixer is an older model and does NOT have phantom power.  So I am assuming I now need a 48v Phantom Power Supply.  Otherwise, will the Radial work without a DC power source?
It looks like the XLR output of the Direct box would go to the Phantom Power Supply input, and from there the output of that box would go to the mixer?  The other option is to get a passive direct box? I am a tad concerned with a loss of signal and overall sound clarity from my guitar.
I have spotted a handful of Phantom Power Supplies on Amazon, all under $30.  Some of these power supplies are fed from a 9Vac source, others use an 18Vac source. Anything in particular I should be looking for?
Thanks,  Tom
Any of those supplies should work fine.  Sounds like the Radial box takes that power and turns it into whatever it needs anyway.
Yes, the phantom power box goes between the DI and the mixer.  And it should do a better job than a passive type would do.
TomCarlos
Quote from: g1 on Today at 03:42:57 PMAny of those supplies should work fine.  Sounds like the Radial box takes that power and turns it into whatever it needs anyway.
Thanks G1 -
I have done some testing today with the Radial.  When going into a mixer with no Phantom Power, it will not pass a signal.  But testing on a second mixer with phantom power works just fine.
I ordered a 48v Phantom supply and it should be here tomorrow.
And as an FYI, the LR Baggs Align Series Active DI works with a 9v battery and 9V external supply. As explained to me (on the LR Baggs Support Page), "The Align DI does not provide power of any kind. It will run on Phantom Power from an amp or mixer, via the XLR output on the DI. If Phantom Power isn't available, the DI will default to DC power. If Phantom and DC are unavailable, it will default to battery power."  That is somewhat confusing - on the one hand the statement says the Align does not provide power but later it says the DI will default to DC power.
