November 16, 2025, 06:28:54 AM
Realistic MPA-100
Started by saturated, October 26, 2025, 09:49:38 PM
The cap has the 4 as a multiplier, not as a digit.  So 33 with 4 zeroes, in pF.
For the transistor sub, power and current & Hfe look ok but I don't think the Vceo of the TTC015B is sufficient.  I would look for the TTC004B.
saturated
Yes sir thanks also I think I learned 1H means 50 v DC  xP
I ask stupid questions
and make stupid mistakes
saturated
Ok
Got my transistors in yesterday so today didn't have a lot of time but hey onward we go
Anyhow wife gave me too much coffee so I had some hella jitters trying to get this in
Also I verified pinout etc
And the ugly truth
Oh yeah that nut that was glued to the board and fell off added to the entertainment
I did not have tons of confidence in this install so I checked for continuity but fingers crossed apparently no solder bridges
So now just waiting on my capaci-TATERS  :'(  :'(
saturated
#18
Too much fun
Just had a cow looking at the collector which appears to be touching the heatsink  :grr
Anyhow I did some more continuity tests and I think it's ok but yeah gonna have to pay attention to stuff like that
EDIT:  note to self.  Next time you need to bend the legs 90 degrees approximate the horizontal distance needed then find a nice firm sharp 90 degree edge to use as a die
Because it also messes up trying to solder when legs are coming through the hole at an angle SMH
EDIT 2: Maybe instead of nice sharp 90 degree edge I should have said nice CRISP edge.  Like when I used to be in Alberta and when I got cold ❄️🥶 the locals would say "She's getting CRISP"
That 'heatsink' looks to me to be a ceramic pad (for heatsinking purposes).
It should be nonconductive.
saturated
Well I got my capaci-TATERS in
Got home from work and installed
Clipped the leads
Reattached the board which was a major pita getting that little spade fork under the ground screw
Powered it up and its about the same it doesn't get loud with both volumes maxed.
Im declaring a marginal "success" because I've had it on for a while and it's not shutting off like it was before.
Also I noticed that the bottom chassis is not getting warm 🥵 anymore.
I just felt the little "heatsink" and it's pretty warm but not hot.
So kinda inconclusive since I wouldn't even know how to operate this amp if it was brand new.  Might be time to get a 🎤 microphone 🎙�
When I first powered it up to test it I got no sound but forgot about this already molested wire wrap so I attached it and had the same low sound.
There are two posts maybe I should try the other one but I don't want to short something out.   :grr
Or maybe I need to study the schematic kindly provided and try to figure it out.
Or maybe they both need to be connected to a wire  :grr  :'(
 xP
saturated
Ok nm yes it does get pretty loud I had the knobs facing away from me I thought the two on the end were aux/phono volume and master volume.
Turns out the tone knob is on the end so when I turned aux/phono it started to get loud.  :tu:
saturated
#22
I want to crank it back up and measure the collector emitter voltage Vce man that's crazy it can get really high.
I told the owner of the junk store where I got it we need to try it out with a mic and maybe he can use it to talk to his shoppers  xP
EDIT:
I attached the mini grabbers to the collector and emitter and cranked it up all to max
I didn't really see any crazy high voltage
Strange I had about 50-55 volts DC and AC at "idle" and when I increased volume(s) it bounced around sometimes hitting 80-90 but settling back down
