November 06, 2025, 04:09:48 AM
Methods for limiting input
Started by edvard, October 21, 2025, 02:39:46 AM
edvard
What's the best way to protect a SS input stage (non-inverting op-amp set for about 5x gain, in my case) from overdriving by overwound or active pickups, or a boost pedal?
Things I've thought of:
- Make the integral gain adjustable via the (-)input leg to ground as a "drive" or "trim" control, and attach a clipping detector circuit with an LED indicator.  I figured out pretty quickly that idea is probably a bit too complicated.
- Run the op-amp at a higher voltage for maximum headroom.  ±15v isn't that much higher headroom, and if I ever experiment with active pickups or overdrive pedals, eek! (I went with ±15v because rated max voltage for most common op-amps is ±18v, but IMO, that's pushing it kinda hard)
- Replace the op-amp with a MOSFET or JFET buffer/booster, so when it clips, it's not harsh.  However, simulations in LTSpice show that contrary to popular belief, MOSFETs and JFETs do indeed clip hard.
- Wire up a bare-bones limiter circuit so the signal never goes over a certain level.
- Instead of an op-amp chip at the front end, build a discrete unit, so I can run it at even higher voltage, because eventually I'll be putting a power amp on the back end, and it'll be running on ±24 or 35 volts.
Or do you simply design it for maximum headroom and let it ride?
In principle, lower first stage gain, there is only so much swing you can get out of a piss poor 9V supply.
For high gain humbuckers or active pickups, often no more than 2X, go figure.
A regular Op Amp, say TL072, can only swing within 2V of 9V or ground so 5Vpp tops.
Rail to Rail Op Amps such as LM833 can swing the full 9V pp
IF you increase supply to 18V or higher, up to +30V single supply, headroom improves dramatically.
edvard
The pre-amp I'm designing is running off of ±12V, and boosts over 5x already start clipping transients, and that's from some overwound mini-humbuckers.  I hesitate to think what full 'buckers or active pickups like the EMGs that can output up to 3V will do. The goal is clean boost at the front end, so all the overdrive comes from everything after that.
So, basically, just design for the most headroom and hope for the best?  There aren't too many common op-amps designed for high voltage, unless I want to use a poweramp like the LM1875 as a common op-amp; that one goes up to 60V (I assume that means ±30v), or new devices like the MAX74810 that can handle 50V.  The cheapest, highest voltage through-hole DIP I could find was the LF356 that can handle 44V, but you have to get the right one.  All others in the LF35x line are 36V, which is still respectable, but that's what most common op-amps will handle, so why look for specialty devices?
I was thinking also some simple soft-limiting up front might be ideal, which would leave the potential for some clipping at input, but then again, there's not many tube amps that are completely clean, and overdriving them is kinda the point, so maybe that would be OK.  Back to the drawing board...
The most standard, tried and true method is a pad/attenuator at the input; either using 2 input jacks or a switch.  Usually labelled Lo and High, or passive/active.
It is still the most common method you will find in use today.
Is there a particular reason you do not want to use this method?  Perhaps trying to address any shortcomings would be easier than trying to 're-invent the wheel' so to speak.
edvard
Quote from: g1 on October 26, 2025, 10:55:07 AMThe most standard, tried and true method is a pad/attenuator at the input; either using 2 input jacks or a switch.  Usually labelled Lo and High, or passive/active.
That's a good idea, but I can't imagine any electric guitarist saying "Hmmm... perhaps I should plug into the 'Lo' input, as I wouldn't want to overload the front end of this fine amplifier".  Well, unless they're playing Jazz maybe...
QuoteIs there a particular reason you do not want to use this method?  Perhaps trying to address any shortcomings would be easier than trying to 're-invent the wheel' so to speak.
Because I'm designing (tinkering, really, if I'm being honest...) a preamp using 3 stages of MOSFET amplification as the dirtifier, and I've found that by keeping the intrinsic gain of each stage low, but boosting the front end, I've got some deep and tasty dirt with much less of the noise that MOSFET circuits are infamous for. I want that front end boost to be as squeaky-clean as possible in order to keep it's own distortion artifacts and harmonics out, as op-amps can sound pretty nasty when you overload them.  After a few pickup experiments, I realized that different varieties of pickups can have huge output differences, so I wanted an easy way to limit the input without simply building a compressor as the front end.
Maybe I'm over-thinking it, and the only time someone else other than me will ever be concerned is if I build one for a friend, and that's fairly unlikely.  I'll put the schematic up here when I get all the bugs worked out and we'll see what happens.
Quote from: edvard on November 03, 2025, 03:07:24 AMI can't imagine any electric guitarist saying "Hmmm... perhaps I should plug into the 'Lo' input, as I wouldn't want to overload the front end of this fine amplifier".
Seriously?  Even if they're using active pickups and the jacks are labelled 'passive/active' instead of 'hi/lo'?  That person would have issues that can not be solved through electronics.  ;)
Here is an example arrangement.  You can see that the only difference between the passive and active sides of the buffer is the single resistor change after it, R105 vs R106.
saturated
I really don't belong in this thread but I'll ask...
Is a DI box possibly useful here ?
And with that I'm out  xP
I ask stupid questions
and make stupid mistakes
edvard
#7
Quote from: g1 on November 03, 2025, 11:14:12 AM
Dude, we're talking possible Metal players here.  Nice bunch of folks, but when it comes to subtlety, well, you know.  "Why should I turn it down or plug into 'Lo' when there's a perfectly good 'Hi' input right there?  'Hi' means 'above', and that means better, right?  TURN IT UP TO ELEVENTY-FIVE AND KICK OUT THE JAMS BUTTER TRUCKERS!!"
QuoteHere is an example arrangement.  You can see that the only difference between the passive and active sides of the buffer is the single resistor change after it, R105 vs R106.
Oh, I'm fully aware of the arrangement and method.  I'm just thinking of a "no-brainer" option.
**Dubious math and assumptions about how meters work follows, please let me know where I go wrong**
I made some possibly inaccurate measurements of my hottest output guitar on an op-amp no-gain buffer with my trusty DMM, and I captured peaks of 150 to 275 millivolts. That's probably at best an average, so lets call it ~300mv max, and assume my cheap DMM is showing me peak-to-peak RMS, so ±212mv.  With that running into an op-amp powered by ±10.7v (which is a ±12v DC supply with noise filtering that drops it a bit) and wired for a gain of 10, I can still hear clipping on some transients from hard strums.  At a gain of 10, my now-±2.12v should come within ~8 volts of either rail.  So, unless my pickups are producing transients 10 times as high as I measure, or my math is WAY off (a very HIGH probability), there shouldn't be any rail clipping at all, right?
