Quadrupler detector circuit
Started by saturated, September 13, 2025, 07:25:54 AM
saturated
I thought this was really cool
But no I certainly do not understand how it works.
I don't see how any signal 🚦 is gonna make it to the top rail  :grr against a reverse biased diode.
It looks simple enough to build maybe I'll check it out  :tu:
I ask stupid questions
and make stupid mistakes
criticism, critique, derision, flaming, verbal abuse welcome
saturated
Reading about the 1N60 is shedding some light on this
 :loco
Quote from: saturated on September 13, 2025, 07:25:54 AMI don't see how any signal 🚦 is gonna make it to the top rail  :grr against a reverse biased diode.
What about the negative alternation of the signal?
saturated
Well I think I'm out of my level here
Anyhow I tried to put this together
Having no 1N60 I looked at three different size diodes I had and went with the middle
Also I had no 100 pf  but scrounged up some 200 pf
I thought this was supposed to be a voltage multiplier so I was real cool starting out a low input but the output was much smaller  :grr
Input
Output (1/2 scale of input)
So yeah this is something I need to investigate elsewhere the source I got it from was IIRC referencing intermediate frequency so yeah that's a whole nother can of worms.
 xP
A detector in most basic terms it is rectifying the signal to create a voltage proportional to signal strength.  The small value caps allow it to quickly change voltage that is detected, as well as being used in it's 'multiplier' aspect.
1N60 is germanium and used because it has a lower voltage drop and will turn on sooner than silicon type, around .3V for germanium vs .6V for silicon.
Any of your diodes will work for the experiment, you will just need a larger signal strength when using silicon diodes.
