2N3904 experiment
Started by saturated, May 02, 2025, 01:36:53 PM
saturated
Some eye opening results after some transistor testing  :tu:
I needed two NPN transistors
-one with lower beta/hFE than 2n3904 (hFE 173)
- one with higher
So I started testing and the first victim mps222A tested hFE 175  :grr
So next I pull out this billy badass radio shack TO-220 TIP 3055.  I'm like oh hell yeah it's on now  8|
It tested 11 hFE.  :grr  retested and got 12  :loco
Tested ecg128 and get a 171....ok keep going  xP
So I had about ten of these puny 2n3391a and wow  8| tested hFE 419  :loco
Now obviously I'm lacking comprehension here I'm sure there is a reason for this and it should make sense.
Anyhow I have my test candidates  :tu:
The protagonist is deeply entrenched in curses from Satan and fights his inner demons to free himself from the curses that plague him.
saturated
And the results are in with some conclusions
When a small hFE transistor was placed in the circuit the voltage drop across the collector resistor was very small or very low collector current
When a large hFE transistor was placed in circuit there was a big voltage drop across the collector resistor ie much greater collector current
Meanwhile...base current remained pretty much constant
So I'm thinking that the base is like a rock.  In response to that I was gonna post Bob Seger like a rock...but I really like fire lake.
(I've been to Cold Lake but not Fire Lake)
Vbe looks "like a rock" because it is being force fed throughn am high-ish resistor (100K)
As of the wide Hfe disparity:
small signal (preamp) transistors are optimized for high gain, they don´t worry about high current because they typically will be used around 1-2 mA or so.
Low dissipation also, 300-500mW (tops).
Power transistors on the contrary are optimized for POWER  :trouble   , high dissipation (70 to 120W), high current (think 10-15 Amperes), etc.
*Everything* in this World is a compromise, so the heavy price paid is abysmal Hfe.
You will find than in all power Amps, power transistors are never used by themselves, *always* driven by a medium power driver transistor, in a Darlington or Quasi Darlington configuration, so their Hfe multiply.
For example my rule of thumb for 50-100W power amps I design is a 2N3055 (Hfe 10 @ 10A) driven by a TIP 31/32 (Hfe 40 @ 1A)) for a combined Hfe of 400, go figure.
I am very conservative (which is safe), in practice combined Hfe is quite higher, but that is a guaranteed minimum value.
Later I switched to power Darlingtons, TIP142/147 (which are a sort of Industry Standard, being also used by Fender Marshall Ampeg Laney Peavey Crate, H&Kettner which should mean something.
Guaranteed Hfe @ 10A is 1000, go figure.
saturated
Thank you very much sir that was awesome  :dbtu:
saturated
I know right now (I think) that all of this is gonna go together like a big 🗝� key lime pie I'm lust learning how to make the crust and missing the key ingredients  :tu:
saturated
Ok thought I would wrap this one up.  Last set of experiments were same setup only now an emitter resistor was added.
This was the first time I couldn't notice a trend maybe I should compare with the other configurations idk I'm still like a mindless zombie doing this stuff.
Anyhow wow an emitter with a resistor wiped out the tpi3055
Ok I did notice something seems this was the first time base current took a hit.   xP
