RG100ESROX
Quote from: g1 on November 04, 2024, 03:53:48 PMYes, DC volts to ground.
Good luck to Utah in the NHL game Tues. (old Jets vs new Jets).  :)
Thanks! We'll take all the luck we can get!
I'll have those voltage readings for you on Thursday.
Thanks again!!
RG100ESROX
#76
Here are the voltage readings you requested for Q-8 thru Q-16.
Voltages are located by the location they were taken within a white square. (maybe it's just me, but the voltage readings don't seem like they are what would be expected (e.g.: -18VDC/-31VDC/+31VDC...strange)
Voltages were taken with a supply voltage of 110VAC because of the current limiter light bulb glow.
Let me know if you have any questions.
-Jay
Those voltage readings are not good.
Especially the -18 volts on the output bases.
RG100ESROX
#78
Quote from: Jazz P Bass on November 07, 2024, 12:29:15 PMThose voltage readings are not good.
So, what should I be checking next? What would be the cause of these odd/bad voltages???
I do have the following parts on hand if needed...
.18R 10 watts x 2
.27R 10 watts x 4
.62R 10 watts x2
2N5484 FETs x 20
TIP31C x 10
TIP32C x 10
2N6254 x 5
Many assorted 1/2 watt Carbon Film resistors
For now, focus on the TIP32 nearest to the trimpot (Q10).
You show +30V at the emitter.  It is a PNP transistor, so if good, the base can only be 0.7V more negative.  Yet you show -18V at the base, which is impossible if the transistor is good.
RG100ESROX
#80
Quote from: g1 on November 07, 2024, 09:17:48 PMFor now, focus on the TIP32 nearest to the trimpot (Q10).
Okay, I'll take a reading on the TIP32C again and get back to you.
Should I be able to get a resistance reading on the 250K bias trim pot? Because I am not able to measure any resistance from any point to any point, or from any point to ground. Does this trim pot have to be removed from the board before a resistance measurement can be taken? Or is the pot bad?? I have some coming just in case.
Thanks in advance!!
-Jay
The trim pot should be 250R, not 250K.  You should be able to measure it in circuit.  And there should be a resistor, R51 in parallel with it (value somewhere between 47R and 100R).
What do you mean, 'not able to measure resistance', is it giving you 'OL' indication?  Otherwise, a reading of zero ohms indicates a short circuit.  Always state the reading the meter shows.
RG100ESROX
#82
Quote from: g1 on November 08, 2024, 02:06:42 PMThe trim pot should be 250R, not 250K.  You should be able to measure it in circuit.  And there should be a resistor, R51 in parallel with it (value somewhere between 47R and 100R).
Yes; it is. You are correct. I just have 'K' on the brain.
I'm not getting a reading when I probe the two front lugs (the reading was erratic and would not settle anywhere), or front to side like I thought I should. And at some point I would think that the DMM would show me 250R regardless of where I have the trim pot set and it's not.
At this point I should probably remove it and try to get a measurement on it out of the circuit. I'll be specific with the readings I measure in my next reply.
RG100ESROX
Readings on the trim pot: (trim pot set to minimum and maximum setting)
Two middle left lugs = 9.0 ohms min/ 39.0 ohms max
top middle to top lug = 9.0 ohms min/ 39.0 ohms max
Bottom middle to bottom lug = 0.3 ohms min/ 0.3 ohms max
Top lug to bottom lug = 0.3 ohms min/ 0.3 ohms max
DMM set to diode test mode:
First TIP32C (Red lead on Collector)
B to C = .556v
E to C = .441v
Readings on the TIP31C (black lead on Collector)
B to C = .537v
C to E = .443v
Second TIP32C - w/heatsink (Red lead on Collector)
B to C = .540v
E to C = .540v
Let me know what ya think and what I should check next.
Thanks in advance.
-Jay
Do diode check for E-B on three transistors above.  With black lead to base, then with red lead to base.
RG100ESROX
Quote from: g1 on November 11, 2024, 02:32:52 PMDo diode check for E-B on three transistors above.  With black lead to base, then with red lead to base.
1st TIP32C black to B/E = .562v
Red to B/E = .590v
2nd TIP32C black to B/E = .284v
Red to B/E = .284v
TIP31C black to B/E = .602v
Red to B/E = .552v
Quote from: RG100ESROX on November 12, 2024, 01:05:54 AM2nd TIP32C black to B/E = .284v
Red to B/E = .284v
Disconnect either the base or emitter from the circuit.  Re-check.
RG100ESROX
You didn't comment on it, but I'm assuming the bias pot is okay based on the fact that there is a 48R resistor in parallel with it?
I'm actually surprised that the bias range of this amp is so narrow. Is this typical for a SS amp??
RG100ESROX
Quote from: g1 on November 12, 2024, 11:51:46 AM
Red to B/E = .284v
Will do!!
RG100ESROX
Quote from: RG100ESROX on November 12, 2024, 12:00:22 PM
Red to B/E = .284v
2nd TIP32C with base removed from board/circuit black to B/E = .596v
Red to B/E = .OL
