saturated's all encompassing inclusive and exclusive bin thread
Started by saturated, September 10, 2023, 03:09:27 PM
saturated
I decided to put a load on it...12k ohm resistor
Similar results
More Bruce
 :P
I have a feeling Bruce says we need some capaci-taters
Here in 1994
I think you have your AC source there hooked up to the output pins.
The error when installed backwards would have reversed the + and - output pins.  The AC would have still been correct as it is non-polar.
saturated
Yes sir thank you  :P
I decided to take a look at this on my scope
Btw here is the source of 12v ac
So connecting scope probes directly to cables coming from ac source
My phone was struggling to get a full trace left to right despite trying to adjust trigger etc the trace was jittery and flickering real bad
So now connect scope probes to (+) and scope ground to (-)
Which I like that but when I had the scope switched to ac I had just a flat line
Then connecting scope probe to (~)
So I guess everything is cool.
I'm off to connect some other stuff to the scope and try to get a better full steady trace.
 :P
Here in 1994
saturated
I'm relieved that my signal generator provided some nice traces
Idk why the trace from that transformer was so sketchy.
Here in 1994
saturated
Good afternoon solid state afficianados.
Hope your weekend is going well at least what's left of it.
:P
I had a question about preparing some banana jack patch cable connectors whether or not these needed to be soldered.
The wires shown are not gonna be used they are only to illustrate the routing of the holes in the metal part.
Maybe I just strip the wire insert it and screw the cap down...idk
Thanks
Here in 1994
JonnyDeth
Quote from: saturated on April 21, 2024, 03:07:37 PMGood afternoon solid state afficianados.
:P
Thanks
Use the compression screw on system for now and decide later on after pondering it a bit if you think soldering will be the best final path. As an electrical/electronics engineer, the "right" way of doing things is not always the best or most rational, and primarily taught for what you should expect if you go to work in whatever cornered field of science your education leads you to where far more educated and experienced engineers told me over a decade ago, you'll ultimately end up only using 10-15% of your education wherever it is you settle in lol.
I'm sitting on a huge regret ATM from trying to repair my Zoom G5 some lunatic woman smashed and doing it the "right" way was a disaster! I suspect my repairs won't be successful but fortunately, the unit overall should still work and I will either have to scroll effects to a different bay of the controls since it has 4 and 2 were broken, or stick to programming it by USB and PC.
The only upside to the destruction of that unit is I bought a 2nd one. I got the damn thing 12 years ago brand new when they were about $450, but for $180 on zZounds which a week later, went right back to the normal price. I have some current generation digital floor units that are absolutely amazing, but this 12 year old dinosaur still outperforms them tonally. Parameter wise, the modulation and effect parameter adjustable functions are quite mediocre.
saturated
I put all the knobs nuts washers etc back on my all time favorite amp
They had been off since you guys fixed it.  I had planned to get around it but never did then I had an intermittent input jack and noticed how bad the chassis was rocking back and forth.
 8)
Here in 1994
saturated
Today I had to make a parallel circuit with a variable resistor
Then do some calculations etc for voltage drops and calculate how many ohms the variable resistor should be for Va to equal Vb
Then make the circuit and do it
So yeah pretty boring but it's definitely helping I have to chug through this in order to get to the cool stuff.
Pretty funny the book noted "although Vo can be directly measured across A and B it is good practice to make all measurements with respect to ground"
 8)
Here in 1994
Quote from: saturated on May 04, 2024, 03:18:47 PMPretty funny the book noted "although Vo can be directly measured across A and B it is good practice to make all measurements with respect to ground"
Does Vo mean V offset?  Where measuring direct from A to B should give zero when they are balanced?
saturated
Yes sir Im not sure what V offset is  :'( but I think they meant compare the two voltages rather than just measure across A and B and turn the pot until it's zero.
At one time I was taking pics of the exercises in the textbook but got kinda wigged out about copyright issues.   :P
Here in 1994
saturated
The fret rest is awesome.  I always knew about them but told myself why do I need one I keep my guitars in cases.
So I bought one used local and it has been a lifesaver
Yes i do love it so handy when setting up... plugging in..or if you need to set it down for a moment
I missed out all these years not having one  :'(
Here in 1994
saturated
Man Joe is getting some really tempting reverb ads on here...must resist  :'(  :P
Anyhow I found that if you are playing a song off YouTube on your phone like trying to learn it while you play...if you hold it up to your pickups it will play through your amp
:P  :-[  :-[  8)
Here in 1994
Quote from: saturated on May 05, 2024, 11:10:45 PMAnyhow I found that if you are playing a song off YouTube on your phone like trying to learn it while you play...if you hold it up to your pickups it will play through your amp
:P  :-[  :-[  8)
I might need to try this...
