October 03, 2025, 05:36:06 PM
newbie question about cranked amp overdrive
Started by dmfp123, December 23, 2021, 01:39:00 PM
Quote from: dmfp123 on December 25, 2021, 02:57:48 PM
YES! An answer at long last... but of course it involved unobtainium :/
Well there are several ways you can go; Buy a kit and poke parts into holes and pray it even works (with 97% chance of tears)
Or learn the basics. (it's taken me 30 plus years with no formal training to grasp how to achieve a great sound)
A lot can be gleaned from the net now and Several sites I know of some well worth the effort.
TeemuK's book Dload on amp design is right here on this site, go here;
https://www.ssguitar.com/index.php?topic=711.0
Also Rod Elliot's site has a massive amount of info aimed at folks like us who are not up to speed on the inner workings of amplification.   Main page: https://sound-au.com/
A simple 20 watt chip power stage here;
https://sound-au.com/project72.htm
Click on, P215 [P27 Revisited] 40W Guitar Amplifier
A complete kit, from 20 to 100 Watt depending on Tr's used. I'm sure there are many other options around if you dig.
One idea might be trying out a few of those small little practice amps that go cheap in second hand op-shops, a lot of those use power chip amps such as the LM1875 which can deliver up 20 watts max,, Check out Project72 link above for some ideas using that chip.
Unlike your amp most SS power stages run clean and have a fairly wide flat bandwidth and although you can do a few tricks with the power section it's going to be easier for the novice to do all the tricks in the preamp. Personally I would suggest a simple single
channel preamp and then start buying or building a few pedals to get the OD.
I did find a pic of what looks like your amp last night and it looks like a large cabinet with a 15" speaker so as Enzo noted that adds to the result.   https://reverb.com/item/2706505-vintage-montgomery-ward-3-channel-guitar-bass-organ-amplifier-15-speaker-usa
FWIW, I rely on pedals now and just use a very basic SS amp, Actually just an old SS Laney keyboard Amp.
For my sounds most fancy pants guitar amps are way to hot rodded. for SS amps I'd rather work with amps that have a simple less tone coloured response and let the pedals do the magic. most hot rod multi channel amps are frustrating as the clean is ok but the other channel/s are often useless and many players end up using pedals for most of the sounds they need anyway.
One wonders why bother spending big money on all the fancy channel switching crap if  all you need is a simple amp and a few pedals. One big advantage of pedals is you can just swap them out if they don't work for you,,No solder needed. win win.
As much as I dislike the idea of a pedal board they prove to be far more versatile than expensive Amps.
If I can blow my own horn here;
I frequent a local open mic gig and the chap that runs it has more sound gear than I have ever seen in my life,, House is wall to wall full,purchases nearly every new Amp/pedal that he can find.
Now I've been playing that gig for 2~3 years so he knows me well and has often made positive comments on my sound. A while back he asked me if I could help him fine tune some of these new amps as he can't seem to dial in the right setting to get the magic.
he added "well you always seem to have the sweet spot and the magic sound"
hum,
I now have to find a kind way to let him in on the simple fact that nearly all the new gear is digital and he will be hard pressed to find any magic as those Vipers and Katanas are very harsh.
Most Guitar amp designs now tend to follow the music fashion trend (i.e. more hard edge metal) I've not yet heard/played one that can do the sweet blues thang.
If you are shredding fast arpeggios all the up to the 49th fret then I guess tone matters little.
If you want to start building your own gear,, be aware it becomes very addictive.
cheers, Phil.
dmfp123
Quote from: Enzo on December 25, 2021, 05:56:04 PM
Did I miss something?  The transformer you link is for a tube amp.  It has a 6v winding for heaters, and a high voltage winding for the B+.   Not suited to a solid state amp.
Yes, well... as demonstrated I don't know what the heck I'm doing, lol
Any idea where to source a transformer with the specs I need? Or even what said specs would be? I think this Wards amp in question has something like 37 input watts but I'd be happy with something a little lower powered if necessary
dmfp123
#17
Quote from: phatt on December 26, 2021, 07:21:11 AM
Yes, agreed, I play many many genres but I never go more than... I don't know, Stray Cats-level overdrive, unless I want a really saturated neck pickup type lead for a soul/r&b part, but even that's miles away from "shredder" territory
The fixation on this particular amp... well, it's two-fold--educational (for the end user) and utilitarian
As I mentioned in my PM I'm a guitar teacher, and I always start my kids out on classical guitar. Invariably one day they either show up and say "I'm in jazz band now" or "I'm getting into this genre of music now" and at that point there's a fork in the road... most still play classical at that point but we start playing electric guitar then, too. This Wards amp on the bass channel is actually pretty fantastic for a piezo loaded acoustic guitar--totally rolls off all those annoying high end frequencies and provides some much needed low end, which is great because they can keep playing the guitar they have & just add a pickup, rather than buying a whole new guitar. For jazz that channel works well too, as do the other channels if you fiddle with the tone knob on the guitar... really 3 solid flavors of jazz tone in that one amp. Neo-soul is popular with kids now and that amp does it. Emo/indie/math rock is popular with kids now and that amp does it. If they want to learn something involving gain... it becomes an excellent learning tool for "this is how amps work, you turn it up and use your guitar's volume to control the amount of gain" etc. So... I guess in short, this amp does everything I need it to do without any fancy channel switching etc, and is really the only amp I've found that does that. The Yamaha THR series is still my go-to for kids who want to get into recording, but for performing purposes it doesn't cut it, it's not loud enough to keep up with a jazz band or even a drummer, let alone a high school drummer.
Of course... parents will often ask for a quieter solution for distortion lol, but I'm not always quick to tell them about pedals. Sometimes I want to force them to play clean for a while before I introduce "makeup for technique". Same with compressor pedals... can make some passages twice as easy to play, but as an educator... I don't always want that.
Obviously you are keen on replicating this amplifier so you will have to work out the circuit.
First you need to find out if the Tx is wired as an *interstage* Tx or if it is an Output Tx. (I'm assuming there is only one Tx?)
If it's an Output Tx then the speaker will be connected back to the Tx directly.
If the speaker is wired back to an Electrolytic Cap then the Tx is likely an interstage setup.
Of course I'm guessing a lot here.
If you really want help to build this then you will have to find all the transistor labels. (looks like there are 4 signal Tr's and 2 power Tr's underside. If you can't work it out then take clear well lit pictures of the front and back of the PCB and post them here.
No promises but I will try. :-\
Quote from: dmfp123 on December 23, 2021, 11:48:28 PM
Any source for the schematic?
I could be wrong, but it seems we have not even found out the model # yet?
Perhaps that would be a little bit helpful?  ;)
Quote from: g1 on December 27, 2021, 02:28:37 PM
Quote from: phatt on December 27, 2021, 09:08:13 PM
Mentioned on the first post, Also I linked to a few pictures I found on Reverb site in (post 15) ;)
I'm not trying to be difficult, but unless I am blind, there is no model # in either of those posts.
Schematics are found by model number.  If we had the number, perhaps we would already be looking at the schematic, which would make for a much more fertile discussion.
Apologies if there is no model # to be found on the unit, but if so the OP should just say that.
Quote from: g1 on December 28, 2021, 02:52:44 PM
You aren't being difficult.  The model name is "Guitar/Bass/Organ amp" by Montgomery Ward.  There should be a model number as well though which no one has shared.  This video shows one of the same name, but very different configuration (head/cab vs combo anyway) vs what was linked to by Phatt.  https://www.youtube.com/watch?v=gWmjj-eag3g
