Each of those 2 output transistors has an emitter resistor. It's too blurry for me to read the numbers but it looks like they are .1ohm 5watt.
So with load connected but no signal, measure the DC millivolts across each of them. Calculate the current through each (V/R).
Mostly you will want to check that they are balanced, and that the current is not excessive.
Not sure exactly what that number would be, but if you post your results any problems should be apparent.
