May 24, 2024, 07:43:43 AM
peavey musician series 400series foot switch
Started by plen, December 12, 2020, 09:36:15 PM
plen
i am looking for a schematic or layout for a peavey musician series 400 series foot switch. any place i can find one or buy one. it is a six pin din cable.
thanks.
Here is a pic of the switch.
I think you are going to be hard pressed finding a 5 button switch.
Do you need all of the functions?
plen
thanks Jazz P Bass for the reply. the foot switch in that schmatic is for seven pin. i need one for a six pin.
That is a 6 pin male DIN plug.
The drawing of Pin #7 uses a flat line to indicate 'attached to shell'.
It's the braided shielding wire to ground.
plen
are the switches latching or non latching. are they spdt or dpdt.
The Selector switch is SPDT.
The rest are SPST.
All must latch.
plen
thanks Jazz P Bass. i will order 4 spst and 1 spdt latching switches.
plen
i just bought a peavey remote foot switch it has 4 foot switches. it is different from the one for my amp. i also bought a 6 pin din socket to try to rewire it because the one on it has seven pins and no center pin.
plen
Jazz P Bass my amp does not have tremolo. it has fuzz. if i wire the foot switch the same as the layout you posted will fuzz replace the tremolo.
thanks peter.
#10
Not too sure what amp you have.
The Musician 400 schematic that I have shows it having Tremolo.
The schematic does not show a footswitch activation for Distortion, just Fuzz. (Pin #1)
The manual states that pulling Pin #1 low (activate Fuzz) turns on Distortion/ Fuzz.
You might want to call Peavey and ask for the correct schematic.
Here is a pic of the Musician 400.
Does yours look like this?
Rate & Depth are the Tremolo controls.
plen
#12
Jazz P Bass my amp has an extra bit at the right it has 2 knobs and says master. one of the knobs is reverb.
This one?  I've seen it referred to as musician 400 series 210 (it is rated 210watts)
