What? Just what large cap were you expecting? This is not a single rail amp like older Acoustics. Look at your schematic. RUns on plus 42 to minus 42 volts. Not plus 90 and ground. The output sets at zero. No need for a fat cap. The fact it is quasi doesn't matter.
Your schematic shows no output jacks. But if I were to guess, I'd say the extension jack puts the extra speaker in series with the main, rather than parallel. SO the sleeve can be grounded, and the tip cutout goes to the sleeve of the main jack. Thus the main jack needs to be isolated.
Why would they do that? If they made it parallel jacks, then any moron could plug a couple 4 ohm cabs in there and load the poor amp to 2 ohms and blow it up. Now a couple 4 ohm cabs makes an 8 ohm load.
We do find schematic errors now and then, but I think it is wise to resist the urge to immediately label something we don't understand as a mistake.
