Hi!
I have find some informations about this today
First quote from ESP, that suggest to use the input stage source as reference :
"A special note for the unwary - If one is to use a single current control transistor for both the LTP and Class-A driver, do not use the Class-A (aka VAS - voltage amplifier stage) current as the reference, but rather the LTP. If not, the varying current in the Class-A circuit will cause modulation of the LTP emitter current, with results that are sure to be as unwelcome as they are unpredictable [ 4 ]. Where the current source reference is based on the VAS (Class-A driver), it's advisable to decouple the voltage reference for the LTP source to minimise interactions."
https://sound-au.com/amp_design.htm)
And a second one, from Douglas Self, that suggest to use the VAS current source as reference, and give an explanation about the base resistor :
"Bias isolation resistors are not unique to the amplifier of Figure 15.1; they are very commonly used. For an example taken at random, see Meyer.7 My own purpose in adding R23 was not to isolate the two current sources from each other at AC (something it utterly fails to do) but to aid fault-finding. Without this resistor, if the current in either source drops to zero (e.g., if TR1 fails open-circuit), then the reference voltage collapses, turning off both sources, and it can be time-consuming to determine which has died and which has merely come out in sympathy. [...]
The original amplifier used an active tail-source, with feedback control by TR14; this was a mere whim, and a pair of diodes gave identical THD results. It seems likely that reconfiguring the two current-sources so that the VAS source is the active one would make it more resistant to feedthrough, as the current-control loop is now around TR5 rather than TR1, with feedback applied directly to the quantity showing unwanted variations"
The amplifier of figure 15.1 is in attachement.
