May 01, 2024, 05:16:02 PM
Gallien Kruger GT200
Started by gbono, September 07, 2019, 06:24:51 PM
According to the schematic, there are two pots that need to be adjusted.
gbono
No bias adjust just two trim pots that adjust the voltage across emitter resistors to get around .05V...I noticed D1 & D2 are across the emitter base of the driver transistors Q7,8,9,10. Are they there to supply the 1.2 V need for the darrlington's VBE? I assumed that the new output devices had a lower turn on VBE but it looks like that may not be the case.
Those sound like bias controls to me.
On your schematic from early on, I see D1,2, but they do not connect to Q9,10, only to the bases of Q7,8.  They do connect to other transistors, but not 9,10.  They do go to the collectors of Q3,4, which are the bias transistors.
Unlike the common complementary SS output stages, this is two single sides stages in push pull.  In other words, the bottom half is identical to the top, just drawn upside down.  SO usually we see one bias transistor between the positive and negative sides, we have two positive sides, so we need two bias controls.
The adjustment is for 1.65v on the base of the drivers - Q7,8.  Qs3,4 draw current through those diodes to set that voltage.  The bias is adjustable exactly because transistors vary.  Whenever outputs are changed, there is no assumption the old adjustment will still be correct.
What did you use for PMD10K80?
.05V across .33 ohms would be 150mA current through those output devices.
That sounds pretty hot.  I would not expect to see crossover distortion with that kind of idle current.
gbono
#19
I substituted 2N6284 for the PMD1603. The trim pots have very little effect over the crossover distortion. I will look at this adjustment again. Also will look at voltages at base of Q7/8 and cathode end of D1/2.
gbono
Adjusted bias at the two emitter resistor and I think there is another typo on the schematic since I can only adjust to 5mV not 50mV. This adjustment has no effect on the distortion.
Can you take a picture of the distortion as it appears on a scope?
If so, upload it.
willpirkle
Yes, picture of x-over distortion. Right at 0V or biased?
Quote from: gbono on December 19, 2019, 03:38:49 PM
I doubt that is a typo.  They show it on the schematic and also state it in the biasing notes on the side.
But even if it were a typo, you should be able to adjust to much more than 5mV there.
I think if you find the problem with the biasing you will most likely solve your distortion problem.
willpirkle
#24
I have a '78 210G which is nearly identical in the power amp, and attached that one (way easier to read). These are just for reference - hope they help someone. The 210G has identical output and bias transistors but emitter resistors are 0.15
willpirkle
Here's the preamp (shows letters).
gbono
#26
Here is output waveform with 8 ohm load 1000Hz. The distortion is not noticeable at low output levels (less than 2VRMS). The crossover distortion increases with output drive - you an still see it a 25 VRMS output level.
Can someone explain this bias scheme to me?
gbono
Merry Christmas and Happy New Year..............
Not too sure what you are attempting to fix here.
Yes there is a small x over notch at higher settings.
I really doubt that you could here that.
What I see from the image is a gross mismatch in the top & bottom width of the waveform.
THAT will be noticeable.
gbono
At 25RMS this amp is in clipping with the negative half of the waveform into clipping earlier than the positive part of the cycle. Both sides of the PA draw from the positive supply rail if I'm not mistaken ....
