April 26, 2024, 10:50:31 AM
Frontman 212r
Started by dlbraly, February 17, 2019, 12:11:35 PM
dlbraly
Hello,
I'm having trouble finding the part number to Drive / More drive switch.
S1 on the schematic.
Can you tell me the correct part number to order?
I ordered the wrong one 0028091049 online, its a little too small.
Thank you for your help and advise.
solderer25
I had a similar problem with a switch I ordered for a Marshall amp. The pins were a slightly smaller footprint so I carefully bent them outwards to make them fit. With a little bit of fiddling I was able to line up the switch plunger with its intended hole in the front panel - job done.
I don't believe that switch is available anymore.
Have you attempted to contact Fender?
dlbraly
Thank You,
I have not had a chance yet to call Fender to ask them.
I will let you know what I find out.
