April 19, 2024, 11:08:11 AM
SWR 550X Bass Amp Trouble
Started by aruption, September 20, 2018, 09:46:35 PM
aruption
Not sure if this is the best forum for this, but some folks on here have helped me out with an electric piano amp, so a bass amp shouldn't be too far fetched, right?
Anyway, a friend of mine asked if I could take a look at his SWR 550X bass amp. It had developed a pretty loud hum, and louder notes from the bass would cause a horribly buzzy clipping effect. This is one of those amps with an 12AX7 tube preamp section. We thought that replacing the tube might solve this, it did not.
What should I be looking at to clear up all this noise? I also had to replace the master volume pot because the shaft had broken off the original pot. The level of the hum increases as the master knob is turned up, as was the case before it was replaced. Any help is appreciated!
Amps are amps, kinda doesn't matter if they are for bass, guitar, keyboards, etc.
First I would check the DC supplies in the amp.  The power amps run on something I know not what.  35v?  50v? 80v?  Whatever, will be plus and minus those.  Make sure the two polarities are about equal voltage and free of ripple.  Also the preamp will likely run on +/-15v supplies, so same checks there.
I would check through the signal path for any op amps putting out DC.
And of course I would check around the input jacks for broken ground solder connections.
tonyharker
The first thing I would do is to check the output for DC. To me it sounds like one of the output transistors has failed.
