May 28, 2020, 10:54:27 PM
Author Topic: SS circuit design questions  (Read 1286 times)
Fossilshark
  • Master
  • Chip Points: 0
    • View Profile
« on: August 03, 2018, 01:27:34 AM »
Hi, i haven't been on this forum in a bit but I've had some questions about SS audio (specifically guitar) circuit design:
I found this class AB circuit and built it with 3904/3906 and got a few watts quality out of it. Can i just pop in beefier transistors and raise the voltage to get more wattage? Do i need to worry about biasing?
If i want more wattage do i need a preamp circuit with more gain?
How would germanium transistors in the poweramp affect the sound? Even if its just a germanium PNP with a 2N3055?
  • Legendary
  • Chip Points: 77
    • View Profile
Re: SS circuit design questions
« Reply #1 on: August 03, 2018, 12:33:16 PM »
Sort of.  You need to back up that higher voltage with higher current capability of the power supply.  It's more about current than voltage.
Fossilshark
  • Master
  • Chip Points: 0
    • View Profile
« Reply #2 on: August 03, 2018, 03:51:27 PM »
Is the current increase due to just a higher voltage on the load resistance?
  • Elite
  • Chip Points: 36
    • View Profile
« Reply #3 on: August 04, 2018, 01:59:41 AM »
I'm not trying to dampen your enthusiasm, but the chances of that circuit working without modification are not very good. If you want simplicity, try a chipamp circuit. Slightly more complicated are the circuits in this thread:
 https://www.ssguitar.com/index.php?topic=3747.0
The circuit I posted in reply #7 can be adjusted to accommodate just about any power supply.
