Did you miss your activation email?
February 18, 2020, 08:31:18 PM
Author Topic: Parallel input stage idea - 1/2 12AX7 ll LND150 ?  (Read 1013 times)
Stephenl
  • Chipper
  • Chip Points: 0
    • View Profile
« on: April 19, 2018, 09:22:54 AM »
I was thinking of trying this, but I don't have a lot of experience using FETs. I'd like to try the conventional arrangement of common Anode and Cathode resistors...but I'm guessing the LND150 will need something different for biasing.
Thanks in advance for any education on this.
  • SSGuitar Global Mod
  • Legendary
  • Chip Points: 429
    • View Profile
Re: Parallel input stage idea - 1/2 12AX7 ll LND150 ?
« Reply #1 on: April 19, 2018, 04:23:48 PM »
They are very different, biasing will drive you crazy.
I would build 2 independent gain stages, each biased properly, join inputs and use a couple mixing resistors to mix outputs, say 2 x 100k or 220k.
Or use a 500k linear "blend"  pot and you can pan from one to the other or get both same level when set to the middle.
