July 12, 2020, 10:06:45 AM
Author Topic: Peavey basic 50 weird sound  (Read 1032 times)
Fossilshark
  • Master
  • Chip Points: 0
    • View Profile
« on: February 05, 2017, 03:03:15 AM »
My peavey basic 50 was working perfectly until i decided to turn the preamp out/power in jack into a speaker out to use with my speaker cab. I have the original jack plugged into the board (so the preamp is still connected to the power amp, i was lazy) and a new jack with the speaker output connected. The amp at first was really quiet now it just makes a wicked loud buzz. The original speaker impedance was 8 ohms and my speaker cab has a DC resistance of 9 ohms (i dont know the impedance im assuming its 8 ohms)
Vitrolin
  • Master
  • Chip Points: 3
    • View Profile
Re: Peavey basic 50 weird sound
« Reply #1 on: February 05, 2017, 11:51:22 AM »
your preamp will not drive a speeaker, that is the power amps job.
the jack you used is like a fx loop
  • SSGuitar Global Mod
  • Legendary
  • Chip Points: 429
    • View Profile
« Reply #2 on: February 05, 2017, 11:24:16 PM »
Something does not add up, you seem to mix jack and plug which are different parts.
Jacks are female and thus do not plug into anything, that´s what plugs do.
So rewrite your post which so far is confusing.
In any case I think you somehow connected speaker out into preamp out and/or power amp in, both a big no-no, and you blew one or both.
Disconnect yoour speaker until further instructions because you will also blow it.
If possible, draw a diagram or what you did, maybe some picture too.
