October 08, 2025, 11:44:51 PM
Tube emulation and temperature
Started by aquin43, November 13, 2016, 05:10:58 PM
aquin43
There are many interesting and reasonably accurate tube emulation circuits but none that I have seen seem to address the variation of semiconductor parameters with temperature. Real tubes work so far from ambient temperature that they are largely unaffected by changes within the normal human range of endurance.
I would guess at 0C to 30C as a useful working range (32F to 86F) for an amp that is to sound the same in world wide ambient temperatures. Is this worrying unnecessarily?
Not quite sure what you are trying to explain or understand but  Transistors are Not Thermal devices,, Valves ARE.
The filament (heater) in a Valve raises the temperature of the cathode which then liberates electrons.
In effect the heater *Biases* the Valve by thermal energy.
whereas a Solid State device runs *Cold* and does not use heat to bias into conduction,,it only needs a bias voltage.
Although there are some differences they do share a lot of similarities but you don't just copy Valve concepts into SS circuits and expect instant Valve mojo ,, you have to use  different approaches to achieve same/similar results.
BTY it's not just the Valves the make a difference it's also due to Output transformers.
If you want more technical terms then there are some here who can give you a much more in-depth explanation.
So yes,,,your Concern is unnecessary 8)
aquin43
The point I was trying to make is that, since tubes operate internally so far from ambient temperature, the transfer function of a tube stage will not change whether the ambient temperature is 0C  or 30C. This is not true of any of the semiconductor based emulators which will show extreme variations with temperature unless this is compensated for in some way. It may not matter much with hard limiters or clippers but anything more subtle will certainly be affected.
I can't recall ever having seen a design where this has been taken into account.
Arthur
  I think that at least for the output transistors, they are also operating far enough from ambient temps that we can also ignore the effect of the ambient temp.
Just a guess though.  :)
QuoteThere are many interesting and reasonably accurate tube emulation circuits but none that I have seen seem to address the variation of semiconductor parameters with temperature.
Oh they do.
Unless it´s the crudest of designs, parameter stability versus temperature change is taken care of.
The basic variation in a Silicon junction, which normally drops "around" 650 mV  , is that it drops 2mV per Degree Centigrade rise, so if you bias a single transistor stage , with its emitter grounded, from a fixed voltage supply, you only need 2 resistors, one in base, one in collector.
In that case, yes, base voltage will change with temperature , and so will collector voltage, a lot more, but practically no circuits are that simple: classic  transistor gain stage uses 4 resistors in a way that operating parameters are quite stable:
A more complex circuit, with 2 or more transistors, in general will have "too much gain"  so negative feedback is used to control gain and reduce any variation to a minimum, both DC and AC.
An Operational Amplifier goes way beyond that, no surprise as they were originally designed for precision lab and Aerospace measurements and Analog Computers.
The one area where temperature variation must be tightly controlled is in power transistor biasing; since currents and power in general are very important, but much worse, drift "the wrong way" and can easily run wild , special care must be taken for compensation.
aquin43
Yes, of course the default design procedures for the linear parts of circuits produce reasonably temperature compensated results, or results in which only the gain varies significantly.
The non linear parts, which form the essence of any tube emulator, will vary with temperature and it will change the clipping points and the low level distortions that are being emulated. That is the part that I was referring to.
Arthur
