November 09, 2025, 05:02:20 PM
LM3886 Amp - Transformer Question
Started by mydementia, January 06, 2007, 06:36:46 PM
ApexJr.
#15
Also for heatsinks:
www.apexjr.com/Sinks.htm
Steve @ Apex Jr
mydementia
Yeah, Steve, I saw those sinks on your site...
I also dug around chipamp.com in the 'completed builds' section and saw one guy using a 3x4x0.5" hunk of copper - that sounds better to me than trying to accommodate a big finned heatsink (something in the 4x6x8" range).
I'm still looking...
mike
The problem is with a solid piece of metal is that it will only work for a certain amount of time without shutting down.  It will basically absorb heat, but not disperse the heat into the air.  Fins are really required to get the job done well.
mydementia
This reminds me of a heat transfer problem from college...
Which dissipates more heat, a heatsink exposed to a volume of ambient air constantly increasing in temperature (Conduction path: Chip-->Heatsink-->Air-->Aluminum Enclosure), or a highly conductive heatsink (copper chunk) thermally coupled to the aluminum enclosure (thus conducting to the larger aluminum enclosure to an ~infinite volume of constantly 'cool' air (Conduction path: Chip-->Copper chunk-->Aluminum Enclosure)
Here's a snapshot of the 'gainclone' that caused me to raise this question:
#19
In case it was unclear to someone, that enclosure is a heatsink and the copper mainly just a thermal conductor to it.
Basically, if you want to use small heatsinks you better decrease all thermal resistances and/or use a fan. The answer to your college problem depends on many variables, see:
http://www.ssguitar.com/index.php?topic=404.msg2976#msg2976
mydementia
How about an old P4 CPU Heatsink?  Looks like 1.25" tall, 2.75x3.25" with 23 fins...
I'm running a single LM3886 (PS and Amp boards/kits from Brian at chipamp.com) with 22-0-22V from the transformer into an 8-ohm load oughtta give about 35W... maybe this will work?
Running at 35 watts you *might* be ok passively, with a fan it would be perfect.  You could always try it and see, the chip has thermal protection so it will shut down before damage occurs.
