April 24, 2024, 11:34:35 AM
Best simple distortion circuit
Started by Fossilshark, May 18, 2016, 10:51:29 AM
Fossilshark
Im looking for a simple distortion setting circuit i can add to my JFET preamp. I tried shunting 2 rectifier diodes to ground on the output for diode clipping but it didnt change the sound at all. So far ive been using my ibanez turbo tube screamer and i really like that sound. Heres my preamp circuit im using
tonyharker
The signal at this point will not be high enough for rectifier diodes to clip. Their forward voltage is too high.  You may get away with germanium diodes however, but you will have to try them.  If they don't work, then its another gain stage I'm afraid.
Fossilshark
So if i added like a single 3904 transistor stage before the distortion it should work?
Frank_NH
#3
If you want to increase the gain, add a 10 uF cap in parallel to the Jfet source resistor.  If you do this, then your diode clippers may work better.
