Simple Preamp please check my work
Started by galaxiex, May 17, 2015, 02:09:31 PM
galaxiex
#15
Here is the revised Pre-amp that I last used with the Cana Kit amp.
Very modest gain of 2.5 to keep the Cana Kit amp out of clipping.
Everyone will notice that I copied Fender's input scheme and the rest is "stolen" circuit fragments from the web.  ;)
This seemed to work pretty good.
Looks good, very good.
Loved its simplicity  :dbtu:
galaxiex
#17
Thanks JM! :)
Simple is what I was going for.
Can get complicated later (but doesn't have to) after the basic amp is working.
Now I am waiting for the 1875 chip to get here....
Oh, btw, anyone see any problem with using the above pre-amp with a split supply?
All the 1875 circuits I see use a split supply.
Can I simply eliminate the bias arrangement (virtual ground?) of R6, 7, 8, 12 and C7 of the above schematic,
and connect the gnd of the op-amp (pin 4) and the FET source resistor R13 to -V of a split supply of say +-15V or +-18V?
All other gnd's go to gnd of course...
Oh wait... pin 3 of the op-amp would also go to gnd, and would the FET gate need a gnd ref?
Argggh, I'll re-draw the schem to see what it looks like...
BRB
Somehow this doesn't look right to me...
Q1 needs a ground reference for it's Gate. A 1Meg to ground or just short out C4.
galaxiex
Thank You Loudthud!
Here we go.
