May 25, 2024, 12:12:57 PM
Jordan Entertainer J110
Started by joshdfrazier, February 18, 2014, 01:19:37 AM
joshdfrazier
Finally received the components for this amp.
Replaced most of the transistors. Bad ones, and ones I was on the fence about.
Powered up through a 60w current limiter, and it works... Sortof. After a few seconds, the bulb begins to glow, and the amp hums badly, and the output begins to distort. The bulb gets brighter, (still orange-ish) and I notice a tiny bit of smoke coming from the board. Quickly shut it off and tried to feel which component was getting hot, but I couldn't tell.
I replaced the "mystery" resistor with a 15ohm. Roly, I suppose your right. As worthless as this amp is, the experience is definitely worth something!
Quote from: joshdfraziersmoke coming from the board
1. Smaller globe.
2. Disconnect speaker
3. Short the bases of the output pair together with a wire link (will de-bias OP stage).
4. Start measuring voltages and write on a copy of the circuit (not the original!).
5. Try to identify the smoker.
6. Post annotated circuit.
