June 06, 2024, 10:59:48 AM
Reverb tank for Crate KX-100 amp
Started by KR, February 14, 2014, 11:02:37 PM
KR
Hey all, anyone know specifically which reverb tank the Crate KX-100 amp uses?
I just picked up one of these amps used, like it but it's missing the reverb tank.
Been searching like crazy to find the specs for it or the replacement part number, to no avail, except that there are a bunch of Accutronic part numbers that Crate used, with a wide range of ohm values, etc...
Thanks!
Its just a common op amp drive, so an EB type pan ought to work.  Non grounded input jack.  The most common pan should work, the 4EB2C1B  Or the 9 or the 8 depending on your size needs and sound taste.
