sometimes i can hold a key down and the volume will jump up to full volume for a split second
a heat issue ic,transistor or something
That sounds more like an intermittent contact/connection. Solid state devices don't just fix themselves if presented with the right frequency.
Method 1 is is guess, randomly replace parts, and get nowhere.
Method 2 is to methodically and logically trace signals and voltages until the cause of the problem is located, then fix it.
Polytone Taurus Elite, front panel;
A couple of tests that suggest themselves are to take a signal from he Preamp Out socket to another amp and see if that sounds normal.
Similarly to take the Fx Send of another amp and inject it into Effects Loop Input and see if a clean high power output can be obtained. That way we will have some sort of idea when end of the amp we should be looking at, preamp or main amp. Also the old trick of linking Fx Out and In with a known good lead.
I must comment that I don't find the control layout on this amp very intuitive.
Inside, the first port of call should be the power supply to confirm voltages for the preamps and output stage (and a cap with a value of 0.047uF is
very unlikely to be an electrolytic).
