Grounding techniques
Started by teemuk, August 21, 2006, 05:28:13 AM
flester
This is amp.  https://imgur.com/gallery/0DvnHiX
Works fine with this ps. not much noise using pedals on battery. https://imgur.com/gallery/49d8gK3
The noise comes in when I use this.
http://imgur.com/gallery/02LCUTt
Works well with a friend's  amp and
Sent from my SM-G935F using Tapatalk
flester
Problem solved. I changed the mains adaptor supplying the pedal power supply. Noise now much at unacceptable level. Thanks again for your input. it stopped me going off om a fruitless and maybe expensive tangent! All for the price of four 9v batteries.
flester
The mains adapter that worked has now died. Any tips on how to buy a new one that is not noisy?
Sent from my SM-G930F using Tapatalk
electrucio
Hi everyone,
I'm new here, pleased to join this forum! I'm picking my audio electronics hobby back up again after putting it aside for a really long time.
https://electrucio.substack.com/p/ground-loops
I would like to share a compilation of ideas I did about this topic, I hope it is useful for someone.
aquataur
#34
Hi,
thanks for the great write-up.
I particularly like the section on ground planes, because people splash ground planes over all PCBs, thinking that this relieves them from a thoughtful routing.
For balanced inputs (and many other hum related subjects), there is a paper by Bill Whitlock from Jensen Transformers called Design of High-Performance Balanced Audio Interfaces, hosted by Rod Elliott. He explains in depth that the balance does not mean symmetric signals, but balanced impedances.
It would nicely fit your write-up.
You may also be interested in:
  • Power and Grounding for Audio and Video Systems
    A White Paper for the Real World – International Version, Jim Brown, Audio Systems Group, Inc.
  • TUTORIAL 5450 (Maxim) Successful PCB Grounding with Mixed-Signal Chips -
    Follow the Path of Least Impedance, By: Mark Fortunato
  • A practical guide to high speed printed-circuit-board layout, by John Ardizzoni (Analog.com)
If anybody thinks - I only do audio stuff, that does not concern me... let me correct that: audio amplifiers love to oscillate in the MHz region. Once at least.
It is really a rabbit hole you are opening up here, but for serious design, it is inevitable to dive into.
I guess all amp designers did so.
Kaz Kylheku
Quote from: aquataur on June 27, 2026, 12:13:33 PMHe explains in depth that the balance does not mean symmetric signals, but balanced impedances.
Indeed, balanced transmission works even if you send signal only down one of the two equal-impedance conductors. (Of course, you must avoid sending identical signal of the same polarity down both.)
The noise is what is counted on to be symmetric: but then both lines have to face identical impedances, so that the noise is subject to identical transfer functions.
If identical but noises are filtered differently, they are no longer identical and do not subtract to zero.
https://www.kylheku.com/mp1https://www.kylheku.com/music-diy
aquataur
#36
An interesting aside, fits nicely to the above linked write-up.
I had to convert a HiFi system to balanced due to hum I could not tame with conventional methods. The preamp was converted to balanced by following the guidelines in Jensen AN-003, INTERCONNECTION OF BALANCED AND UNBALANCED EQUIPMENT by Bill Whitlock (fig. 2.4).
Since I expected problems with my makeshift balancing, I bought chips from THAT Co for the input side of the power amp, Series 1200 because:
Quote(...) conventional input stages measure well in the lab and perform well on paper, they fail to live up to their CMRR specs when fed from even slightly unbalanced source impedances — a common situation in almost any pro sound environment.
That sorted the problem out in no time.
Incidentally, it was the same Bill Whitlock that designed the chips for THAT.
electrucio
Thanks for your relevant feedback, I updated the section about balanced inputs with the concepts you describe: https://electrucio.substack.com/i/192899322/electronically-balanced-inputs
I will check also the other references you suggest. Indeed, this is truly a rabbit hole with no exit on the other side :cheesy: .
aquataur
#38
Kevin O´Connor has an entire book about the subject, although bits and pieces are scattered all over his books.
He speaks of a "galactic" grounding scheme, using a picture of many stars residing in a galaxy. Maybe of interest in this context.
Fenders in fact are wired that way. There is local stars on the turret boards interconnected via a big brass strip "back-bone".
aquataur
Hi R.G.,
we meet in the most obscure places😉.
Never knew about your book, thanks.
Greetings,-H
R.G.
It wasn't meant to be a book, it just got that way.  :)
I thought I'd write down a few groundig and hum avoidance tips, maybe a page or two. It kept growing as I went and the first draft was over 40 pages. A few illustrations to visualize some points, and...  well, it kind of grew up.
And anyway, some of the best places are the most obscure.   8)
aquataur
@electrucio: for your comprehensive list, maybe of interest (some entries may be already existing):
  • Power and Grounding for Audio and Video Systems - A White Paper for the Real World – International Version, Jim Brown, Audio Systems Group, Inc.
  • RaneNote, PIN 1 REVISITED
  • So You Thought Your Amplifier Was Balanced? No matter what the advertising or manual says it probably isn't! http://www.audionote.co.uk/articles/art_balanced.shtml
  • A Ham's Guide to RFI, Ferrites, Baluns, and Audio Interfacing, by Jim Brown K9YC, Audio Systems Group, Inc.,http://audiosystemsgroup.com
  • Jensen AN-004, HUM & BUZZ IN UNBALANCED INTERCONNECT SYSTEMS,by Bill Whitlock
  • Ground and (safety) Earth, by Eric Juaneda, January 2008,http://tech.juaneda.com/
  • Audio Component Grounding and Interconnection, Dave Davenport
this is not an easy subject.
