what exactly is a preamp
Started by franklin01, August 19, 2006, 10:53:48 PM
Jack1962
I have to disagree with Guitarist , Impedance is a concern , if they don't relative match you have loading problems which effect tone .
                                                  Rock On
Impedance matching is a rather vexed question - it depends a great deal on the situation.
Strictly speaking we match the impedance of the load to the source to achieve maximum power transfer.
In the case of valve (tube) amps the high output impedance of the power amplifier valves is matched to the much lower speaker impedance using a transformer, and in that case something close to an impedance match is sought.
With the line voltage level connection between preamp and main amp it is voltage not power that we are trying to transfer and therefore no attempt is made to match impedances.  The output impedance of a preamp will be low, hundreds of ohms to ohms, and the input impedance of the main or power amp will be very much higher, 10's of k ohms up.
These two impedances are effectively in series and divide the actual output voltage source, so making the ratio between them very high drops the least voltage.
Similarly where the output of a solid state amp drives a speaker the output impedance of the power amplifier will be a small fraction of an ohm while the impedance of the speaker(s) will be typically 8 ohms (but maybe 16 down to 4).
If we tried to actually match the impedance of the solid-state output stage for maximum power transfer, half the power would be dissipated (uselessly) in the output stage electronics as heat, and the other half in the speaker(s).  Typically this would also grossly exceed the current capacity of the output stage and destroy it.
Impedance mismatch is actually used all the time to limit the available power, and no attempt is make to match the impedance of your toaster or electric jug to the power station because, if it were, you would get half the power station capacity appearing in your kitchen - both spectacular and unhealthy.
So these appliances are constructed with a deliberate and gross impedance mismatch to the power station so that they only dissipate a few hundred watts of the megawatts the power station is churning out.
In radio systems, such as CB antennas, the object is maximum power transfer, voltage and current, so the antenna is matched to the impedance of the transmitter output stage.
@Onewatts - this is another case again, where the multi-effect is used mainly for signal conditioning, and PA system inputs actually have much greater voltage sensitivity than your typical guitar amp input.
You would consider this a preamp in the guitar amp sense of the term of lifting signal voltage level if it only fed a power output stage, say via Fx Return, but very generally most Fx units won't produce the sort of voltages required by most main amps for full output (e.g. 100mV v 1 volt).
Suprdan
different preamp devices do different things .  basically it takes your smaller input signal like a Mic or a guitar or the out on your tuner and amplifies and allows you to shape the sound and make the output signal more bigger.  stomp boxes boost the signal to the input of a combo amp but the pre amp in the combo amp also amplifies and shapes the signal bigger so the power amp has the right size signal and impedance to drive the speakers ultimately...  some are designed for mics or turntables or pianos or guitar pickups all have different stages and levels of audio signal they are designed for... if u break it down
pre - before
amplifier - device that magnifies sound or signal
it's a amp that is for driving your next amp up to the power amp which drives the speaker or load.
I wanted to answer the question in my own words but if I have any misinformation here i will be happy to fix it.
duckduckgoose
If a preamp is put before the guitar cable like in an active pickup preamp I think it also helps with signal to noise ratio
JonnyDeth
The best way to regard a preamp is as a SSA; Small Signal Amplifier which is the technical term. It gives a small amount of amplification to the device used to directly produce sound, and has some amount of control over altering the signal, even if it's just a single knob.
In reality, every pedal on a pedal board is a preamp and then your guitar amplifier itself will have a preamp with a power amplifier in it. They pre-amplify the signal before being sent to a power amplifier. They are also conditioning your signal in such a way that it will potentially be in much better condition for the power amp to have stability and evenness in it's performance of power amplification.
It may even only provide unity gain, which means a factor of 1x, and balance impedance for the sound source it is specifically designed for.
A preamp is also regarded as an "addition/subtraction" stage of signal amplification; features of the signal directly created by the sound source are both added and taken away.
