May 08, 2024, 08:15:53 AM
Joe Davisson's new Guitar amp
Started by syndromet, August 10, 2006, 02:25:45 AM
yaff
So, is there anybody made this new JD diode compression power amp? What about it's overdrive?(only power amp)
Joe
#121
Finally finished this project. Ended up using a Dr. Boogey style preamp, but added channel switching and fx loops. It's all pretty basic but works. Turned out to be a reasonable fascimile of the original, but a little harsher sounding.
Decided against using the diodes in the power amp section, like Teemuk said the amp soft-clips anyway and sounds great cranked on its own. Seems more stable this way too.
Overall not bad for a SS amp, sometime I would like to redesign the power amp board and use a pcb for the preamp instead of rat-shack perfboards (and the rat's nest wiring job I did) :)
Edit: Drew up the power amp in its final state.
Any sounds clips or pics of the final version?
