June 16, 2024, 12:18:03 AM
Marshall amp, strange noise
Started by tinpan, June 05, 2011, 06:29:58 AM
tinpan
I have a solid state Marshall Valvastate VS230, works and plays fine except sometimes inbetween songs it makes this whining sound, it's hard to explain but when nothing is being played, no effects plugged in just straight guitar with a known good cord it makes this sound, similar to hearing when a drill or blender is being used over an AM radio but there is nothing being used. The sound will appear then sort of break up then go away. Im a tv repair tech so if this is something where all I need is a resistor or a cap or IC I can do it myself, I looked at the circuit board and nothing looks burnt and solder joints all look good. Anyone know what this is?
"Nobody leave's this place without singing the blues" (Albert Collins)
Does it happen at the same time every day?
Quotesimilar to hearing when a drill or blender is being used
Well, *maybe* a drill or blender *is* being used somewhere close and you don't know it.
Computers, TVs and monitors, not excluding switching power supplies (which are everywhere, such as your Cellphone charger) and even Cellphones themselves, which regularly chirp "I'm here" to nearest tower, all contribute to electrical noise.
Something funny that happened to me: I live in La Boca, the ancient Buenos Aires port , less than 100 meters from the waterline.
Once, at different times of the day, I heard *everywhere* (even on my TV and my phone) this "... zzzt ... zzzT ... ZZZT ... click click click ... ZZZT ... zzzT ... zzzt ..." sound.
It was maddening.
A shipowner neighbour visited me, and when he heard it said "are you repairing a Marine Radar .... ?"
Turns out there was this Spanish fishing ship anchored one block away, which was being repaired, testing illegally their Radar.
They have a high power setting for navigation use and a low power one for port use.
tinpan
Quote from: phatt on June 05, 2011, 06:34:05 AM
No, not same time. random.
tinpan
Quote from: J M Fahey on June 05, 2011, 10:31:28 AM
It was maddening.
I only use the drill and blender thing as an example, the sound is simlar. however my pc is on as I use it to practice with, I use jam tracks. And altho we are on an island we are miles from any port.
LJN
That sounds like some kind of interference to me. My amp does that sometimes, In fact, most of the amps I've owned did odd things like that. I had 2 tube amps that would pick up radio signals. Try putting your amp in a different position, and see if the noise changes. I've found that it helps to move the amp sometimes. I'm pretty sure that's all it is, is interference.
If it sounds good, USE IT!
